DirtyChevy's Project
DirtyChevy45
Re: DirtyChevy's Project
Post by DirtyChevy45 » Tue Jun 27, 2017 1:04 am
life happens to the best of us but looking forward to getting this going again!
Post by GRAVETXT-1 » Tue Jun 27, 2017 8:06 pm
Cool did you order this direct off Boyer or bought it second hand?
DirtyChevy45
Post by DirtyChevy45 » Thu Jun 29, 2017 12:06 pm
directly from the man the myth the legend himself lol.
DirtyChevy45
Post by DirtyChevy45 » Tue Jul 04, 2017 10:13 pm
What are you guys running for gears? pinion and ring gear size? got my axle housings and need to get the guts.... here are some pics !
DirtyChevy45
Post by DirtyChevy45 » Mon Jul 10, 2017 4:32 pm
thanks to mike over at screw loose hardware got my axles and shocks mounted got some more parts in today should be able to get my rear diff in and tires mounted on the back!
Post by andymac0035 » Wed Jul 12, 2017 4:01 am
Dang! Very impressive! 8)
DirtyChevy45
Post by DirtyChevy45 » Wed Jul 12, 2017 12:06 pm
thanks bud! having trouble with the internals of the axles and about to get some lockers front and rear untill i can figure out this open diff stuff....
DirtyChevy45
Post by DirtyChevy45 » Fri Jul 14, 2017 2:00 pm
just an update:
with no help from the support people over at Rc4wd i managed to get the diff working decent enough to keep together and see how it runs. it took alot of head scratching and measuring different thickness o-rings and shims i had available and coming up with a combo that seemed to suffice. the end caps on the axle seemed a little tight but managed to get them on and i forsee them loosening up after everything wears in. filled it with my special lubrificant and it seems to be working great so far inside the not so sealed diff cup.
DirtyChevy45
Post by DirtyChevy45 » Wed Jul 26, 2017 5:43 pm
updates
dubbl-a
Post by dubbl-a » Thu Jul 27, 2017 1:56 am
The build is coming along great!
The upper shock mounts are interesting but seem to be a very strong setup. Any particular reason you swapped out the G-mades for King shocks? I like that you went with the Freestyle trans. I've been tossing around the idea of getting one for my KK2 but have had good luck so far with an all alluminum steel geared SCX10 trans. Let us know how you like it. :)
DirtyChevy45
Post by DirtyChevy45 » Thu Jul 27, 2017 1:41 pm
Thanks bub! only reason i swapped for the kings is because they are a bit longer and made it to where i could get the upper mount off of the lowest setting for height. it most certainly needs a sway bar setup. its very well built and uses steel/aluminum gears inside right from Josh. i'm tossing the idea of what form of lubricant i want to run in it... i'm ready for some electronics next and hung up on what castle product i should get and kv motor size... think ive found the savox servo i'm gonna try.
matt1ptkn
Post by matt1ptkn » Fri Jul 28, 2017 12:44 pm
I'm starting to think that I need to make my next project, after my SCX10, a tube frame truck. Your trucks looks fantastic! What is your wheelbase? It looks perfectly proportioned. :thumbsup:
-Matt
DirtyChevy45
Post by DirtyChevy45 » Fri Jul 28, 2017 9:02 pm
thanks bub the scx10 is great i may get one eventually. ill have to measure to verify when i get home.
DirtyChevy45
Post by DirtyChevy45 » Mon Jul 31, 2017 1:03 pm
WB is right about 13in
DirtyChevy45
Post by DirtyChevy45 » Tue Aug 01, 2017 1:55 pm
starting to look into my electronics... think i got the steering servo picked out just not sure on battery, esc and motor. was thinking a castle combo but not sure which KV motor to go with. don't want anything getting to hott. any suggestions?
Users browsing this forum: Google Adsense [Bot] and 6 guests
