SC10RS build
Zac_F85
SC10RS build
Post by Zac_F85 » Sat Sep 20, 2014 8:46 pm
some of you know I was looking for another SCT and was looking at a Slash 4x4 Platinum. Well I just bought a SC10RS instead with the advice of a few on here and figured I'd start a thread for it - in my start a build thread before I get the kit form as usual LOL
This truck comes RTR w/ a 3300kv brushless motor/ESC combo , 2.4ghz radio - 2wd - Jconcepts soft compound rear tires, and I got the Rockstar Makita body version - The RS also comes with a few things the standard RTR doesn't - aluminum shock bodies -pretuned with springs/oil, Jconcepts rear tires, and brushless setup.
I ordered with the truck -
Jconcepts 79 Ford body
Jconcepts overtray
Jconcepts 84t spur gear
Robinson Racing 48p pinions (20/22/24)
AKA Gridiron S3 tires
HPI mk.8 2.2/3.0 SCT wheels
MIP ball dif kit
pair of Dean's female plugs for my battery
What my next order will be -
RJ Speed interior
AE Factory Team front and rear spring kits
AE Factory Team blue 12mm hubs
AE Factory team Titanium turn buckle set
AE ESC fan
RPM rod ends (Black)
I have wanted to drive on a RC track since I got back into RC's a few years back and haven't done so yet - First plan is to check the truck over very well, solder the deans on the battery and fly it up and down my road/yard a little - then off to the track on a Saturday! maybe bring a couple upgrades like the new wheels/tires with and see if it'll make a noticeable difference!
Zac_F85
Re: SC10RS build
Post by Zac_F85 » Wed Sep 24, 2014 11:16 pm
Got the truck and went and broke it in on a dead 2S battery yesterday haha - it's fast fro sure - I went up to a 20t pinion and I am going to gear it lower I think as it may be to slow in the low rpm range for a track - I got the new wheels tires mounted but not glued and found they're to wide for the stock body SO I stayed up and trimmed/ mounted the 79 Ford body and took a teaser pic..
I had to trim the plastic 12mm hubs to get the tires to not rub in there travel and I'm betting they will rub when the front is turned either way... I want clamping hubs anyway so Jconcepts one's will be ordered (front hubs for the front and rear) adn the front's will get a good shaving down to at least 4mm thick
Zac_F85
Re: SC10RS build
Post by Zac_F85 » Fri Sep 26, 2014 10:04 pm
Well got a lot done to the body - pretty much done - looks pretty good! Wish Proline still made the SCT truck interior - I made one but need a 1/8th scale driver as the 1/10 driver I have looks like a 5yo kid in the truck haha
Let me know what you think!
Re: SC10RS build
Post by SFC K » Mon Sep 29, 2014 8:47 pm
That paint job turned out great Zac! Did it come with those ribbon decals or did you have to custom make them?
Zac_F85
Re: SC10RS build
Post by Zac_F85 » Thu Oct 02, 2014 12:02 am
SFC K wrote:That paint job turned out great Zac! Did it come with those ribbon decals or did you have to custom make them?
The Red/Orange/Yellow? No it did not come with them- Those are from the HPI 79 Ford F150 - uncut - I might add just re-arranged to work in the way you see
I was rather unhappy that the decals they show it with (advertise it with no less) do not come with it.. as I like them - but this turned out great as a vintage looking truck for sure!
I made my final order for this truck -
AE tit. turnbuckle set
AE tit. .630" turnbuckle
AE .187" x .500" bearings
AE front spring kit
AE rear spring kit
AE rear sway bar
AE ESC fan
Robinson Pro Aluminum 48p 15t/16t/17t pinions
RPM 4-40 Black rod ends
RPM front and rear lower arms
RPM front bumper
RPM rear axle carriers
Jconcepts front 12mm clamping hubs (got 2pr for front and rear)
STRC aluminum front hinge pin brace
RJ speed interior
I also have the MIP ball dif that will be installed at the same time as these upgrades
Zac_F85
Re: SC10RS build
Post by Zac_F85 » Thu Oct 02, 2014 11:54 pm
Had a crappy day and splurged - got a Tekin RS gen2 and Redline 10.5T combo for the truck today!
Re: SC10RS build
Post by SFC K » Thu Oct 02, 2014 11:57 pm
You got some coin tied up in this thing now! :shock:
Zac_F85
Re: SC10RS build
Post by Zac_F85 » Fri Oct 03, 2014 12:35 am
SFC K wrote:You got some coin tied up in this thing now! :shock:
HA! ya I am thinking about selling my SCX10 to recoup some money to build my next project - Ofna GTP2 EP with the new Parma 71 Muscle SCT body on it - (that body is a 71 Dodge Demon and I happen to have the real car I'm building)
I hear so many good things about the SC10 though that I'd like to try and make some serious effort into racing and it's what everybody runs in Starbuck (Tekin and Team Associated) and other tracks around MN
Plus I don't like the cogging of the AE unsensored system at low speeds - I coulda got the Novak Edge2S and Ballistic 10.5T for $175 (got the Tekin RS for $250) but I've heard of them thermalling from the low turn motors
Re: SC10RS build
Post by SFC K » Fri Oct 03, 2014 12:48 am
Well, you have done your homework and should be set-up good for racing. I have had good luck with the Novak systems and prefer them with the sensored. I have the Havoc system in my Blitz and ran it over in Kuwait even during high temperatures and it never skipped a beat.
Zac_F85
Re: SC10RS build
Post by Zac_F85 » Fri Oct 03, 2014 12:57 am
SFC K wrote:Well, you have done your homework and should be set-up good for racing. I have had good luck with the Novak systems and prefer them with the sensored. I have the Havoc system in my Blitz and ran it over in Kuwait even during high temperatures and it never skipped a beat.
See I loved my Novak system in my TFR201 as well - that was a Edge2S and 13.5T SS motor.. and just wanted to try the Tekin system since my coworker, his brother, and the owner of the Starbuck track swear by them
Zac_F85
Re: SC10RS build
Post by Zac_F85 » Sat Oct 04, 2014 11:31 pm
Lost the instructions for the MIP ball dif :( BUT got the front end all swapped out (titanium turnbuckles, RPM arms/ front bumper, and STRC aluminum hinge pin brace)
Got the rear half done - got to assemble the ball dif and install it in the trans and put it back together! Then on to detailing the RJ Speed interior for the Ford body and tape that up so it's finally done
Also seen AE installed the 3.5* toe hinge pin mount which is a little much to me and they included 2.5,3.0,3.5,4.0 and 1*,2* rear caster spacers - which I left the 1* plate in and installed the 2.5* pin hinge pin mount
The Tekin RS2/10.5T setup will be here Monday - and also scored a Savox 1257TG servo, Black aluminum servo arm, and another pair of SC10RS rear race wheels/tires for the truck so those should all be here Tuesday-ish.
I decided instead of buying another body to race it as the Ford is to nice and the wheels are illegal (they have 4.5mm offset (9mm total) AND 3mm (6mm total) is the limit - the stock kit wheels have 3mm each) - I'd just use the Rockstar one it came with as well as the wheels/tires the truck came with (Jconcepts tires in rear - and bought another pair brand new for $20 shipped for the fronts)
Zac_F85
Re: SC10RS build
Post by Zac_F85 » Tue Oct 07, 2014 10:25 pm
The new ESC,motor, and servo came today!
Tekin RS Gen2, Redline 10.5T motor, and a Savox 1257TG titanium gear servo (servo bought used)
JKRacing37
Re: SC10RS build
Post by JKRacing37 » Fri Oct 10, 2014 12:53 pm
That paint is amazing! =D>
Zac_F85
Re: SC10RS build
Post by Zac_F85 » Tue Oct 14, 2014 11:33 pm
JKRacing37 wrote:That paint is amazing! =D>
Thanks! I like to do a decent job on my cars/ trucks for sure
