Granddad Stinky's Monster-ish Truck Build (Well, as monsterish as I can make it)
Granddad Stinky
Post by Granddad Stinky » Thu Jul 20, 2017 7:05 pm
It all started with this and no ground clearance. At least it's 4WD!
Granddad Stinky
Re: Granddad Stinky's Monster-ish Truck Build (Well, as monsterish as I can make it)
Post by Granddad Stinky » Thu Jul 20, 2017 7:11 pm
Swapped out the pathetic plastic diff gears for DF-02 metal ones.
Granddad Stinky
Post by Granddad Stinky » Thu Jul 20, 2017 9:11 pm
Starting the mock up, to see where stuff goes, then the body arrived.
Post by Sixtys Guy » Fri Jul 21, 2017 10:07 am
Unique build! I've been tempted to buy one of those buggies, but have resisted thus far!
Granddad Stinky
Post by Granddad Stinky » Fri Jul 21, 2017 11:18 am
They're really tough but be prepared to shim and bush things, there's a lot of sloppy joints.
Granddad Stinky
Post by Granddad Stinky » Fri Jul 21, 2017 11:21 am
Hi-tech body height setting system!
Granddad Stinky
Post by Granddad Stinky » Fri Jul 21, 2017 11:24 am
DF diff gears don't fit TT casings!
Granddad Stinky
Post by Granddad Stinky » Fri Jul 21, 2017 11:26 am
Machined to fit.
Granddad Stinky
Post by Granddad Stinky » Fri Jul 21, 2017 11:28 am
45mins + £1.06 of aluminium = 1 custom prop shaft.
Granddad Stinky
Post by Granddad Stinky » Fri Jul 21, 2017 11:57 am
Nooo Shox.
Granddad Stinky
Post by Granddad Stinky » Sun Jul 23, 2017 12:25 am
Anyone interested in this? Shall I carry on?
Post by andymac0035 » Sun Jul 23, 2017 2:34 am
Please do! I am very much enjoying watching you work. :thumbsup:
:popcorn: :popcorn: :popcorn: :popcorn: :popcorn: :popcorn: :popcorn: :popcorn: :popcorn:
Granddad Stinky
Post by Granddad Stinky » Sun Jul 23, 2017 4:33 pm
Ok, cool! Thankyou.
Granddad Stinky
Post by Granddad Stinky » Sun Jul 23, 2017 4:38 pm
Now the new shocks have arrived I can start fiddling with the ride and body height properly. This is a template for the shock towers.
Granddad Stinky
Post by Granddad Stinky » Sun Jul 23, 2017 4:42 pm
As it's a buggy base, I'll need to engineer as much suspension movement as possible.
Axle cups catching on suspension.
Front hub carrier corners digging into suspension.
