BLackfoot esc and motor
l300lover
Post by l300lover » Mon Jul 17, 2017 6:28 pm
I'm going to purchase an original blackfoot soon. can I run a 550 traxxas titan 12t motor or will it not fit? I already have the traxxas XL-5 esc for it.
Re: BLackfoot esc and motor
Post by andymac0035 » Mon Jul 17, 2017 7:07 pm
I do believe it will fit. Keep an eye on the motor shaft when you install it. The titan motor has a longer shaft. On some trucks I have had to grind it shorter.
The motor itself is also longer (the can) but I don't think there is anything in the way for it to hit. I'm just guessing here though, so take that with a grain or salt.
Post by andymac0035 » Mon Jul 17, 2017 7:09 pm
Unless the suspension lets the tire come up and hit the longer 550 can, then I don't see an issue.
l300lover
Post by l300lover » Mon Jul 17, 2017 11:40 pm
Cool thanks guys! How will I know if the motor shaft is too long?
Post by andymac0035 » Tue Jul 18, 2017 2:23 am
It will hit against the inside of the case and not let you tighten the motor in all the way.
l300lover
Post by l300lover » Tue Jul 18, 2017 9:54 pm
What are the capacitors that came with the traxxas xl-5 esc? And how do I use them?
Post by andymac0035 » Tue Jul 18, 2017 10:26 pm
They get soldered onto the motor where the wires go. New 12T motors come with them already, so you should be fine.
l300lover
Post by l300lover » Tue Jul 18, 2017 10:31 pm
Col thanks I checked and the caps are on the motor! :)
Post by TamiyaTony » Sat Dec 23, 2017 10:22 am
I have the Traxxas 12T and XL5 esc running on my Monster Beetle with no problems at all. That combo is stupid fast!
