e-maxx spur gear compatability
Irio - esos
Post by Irio - esos » Fri Oct 24, 2014 4:06 pm
I use an emaxx trans and was wondering if anyone knew the size of the hole in the middle of the spur gear. My calipers say 9.3mm but i'm wondering if thats a little off. I'm hoping its actually 9.6 so I can fit the RC4WD spurs that are 9.6mm. Specifically something like this.
http://store.rc4wd.com/52T-32P-Delrin-S ... _3419.html
If not, anyone know a source for a low tooth count, ie 60 or less spur that will fit the emaxx first gen trans?
mavrick0
Re: e-maxx spur gear compatability
Post by mavrick0 » Fri Oct 24, 2014 4:30 pm
If you are looking for a spur that looks like that why not try a traxxas revo spur gear. Their teeth count go from 36t and up.
Irio - esos
Post by Irio - esos » Fri Oct 24, 2014 8:05 pm
Didn't think about that, will it fit on the first gen trans with the spacer on the hex shaped output shaft?
mavrick0
Post by mavrick0 » Fri Oct 24, 2014 8:26 pm
I couldn't tell you. It's been so long since I've touched a first gen e-maxx tranny.
