Emaxx clod wheel adapters
mrgrimm
Post by mrgrimm » Sun Mar 11, 2012 3:57 pm
I added an old 3906 Emaxx to my fleet over the weekend, and I am curious as to what options are out there for running Clod wheels/tires on the truck?? I have been searching around and finding some options, but what experience do you all here have with doing this?
Monster trucks rule :)
Thunder VP
Re: Emaxx clod wheel adapters
Post by Thunder VP » Sun Mar 11, 2012 4:23 pm
TTR made adapters a few years back but i do not believe there are any left.
You might be able to replace the 14mm hexes with 12mm hexes and use standard Clod wideners.
mrgrimm
Post by mrgrimm » Sun Mar 11, 2012 10:17 pm
Those TTR adapters are very nice!
I do have some extra Clod wideners that use the 12mm hex, I guess I could grind the pin slot bigger and enlarge the axle hole on some plastic 12mm hexes. I would then need to track down some correct barrel nuts because these Maxx axles have a large diameter compared to the Clod. Thanks for the advice, I may give it a try if I can't find any adapters.
cloddog3222
Post by cloddog3222 » Wed Apr 30, 2014 5:55 pm
Hi,I found my adapters from esp for my 3906 emaxx,they are all machined aluminum,very nice,they are like sixty dollars for all four.
