tire ballooning issue on erevo
cher9498
Post by cher9498 » Thu Aug 18, 2011 11:46 pm
is there any way to stop the tires from ballooning on a brushless erevo other than driving slow?
duct tape is like the force it has a light side and a darkside and binds the universe together
(from a scientist on the history channel)
Re: tire ballooning issue on erevo
Post by andymac0035 » Fri Aug 19, 2011 12:55 am
Take the tires off and put a few layers of duct tape on the backside of the tread (inside).
If you look on youtube it's called taping or strapping tires.
cher9498
Post by cher9498 » Fri Aug 19, 2011 2:55 am
that sounds better than my idea
i was thinking of drilling 4 holes thru the tires and putting screws with washers :lol:
slapshot1979
Post by slapshot1979 » Fri Aug 19, 2011 12:35 pm
andymac0035 wrote:Take the tires off and put a few layers of duct tape on the backside of the tread (inside).
Bingo, Ive done the same. wipe any residue off the tire and try and achive the best "bond" possible, hard to redo once they are glued to rims.
132NHAF
Post by 132NHAF » Fri Aug 19, 2011 2:44 pm
Actually, one layer will do. Definitely check out the Tube for ProLines videos on this. After doing this, balancing will also help with high-speed wobbles. Somewhere in here there is a picture of the stand I built for a few dollars.
Scott T
Stickers...Get your ClodTalk stickers here: viewtopic.php?f=2&t=25953
It's not WHAT toys you play with, but that you play with toys at all that is important.
cher9498
Post by cher9498 » Fri Aug 19, 2011 3:34 pm
i remember that stand you built
cher9498
Post by cher9498 » Fri Aug 19, 2011 3:36 pm
i have alot of bugs to work out with this truck i reprogramed the esc so it stopped doing front flips when i let off the throttle . now if i turn with any speed it flips. has anyone put a fitting in the wheel and aired these tires up ?
could that make it better or worse?
Post by charliechristmas58 » Fri Aug 19, 2011 5:23 pm
There is a kit that you can get that lets you do just that. some people put water in them. but you well have to get a solid rim for that.
cher9498
Post by cher9498 » Fri Aug 19, 2011 5:40 pm
charliechristmas58 wrote:There is a kit that you can get that lets you do just that. some people put water in them. but you well have to get a solid rim for that.
i believe they are solid. i was thinking of drilling a hole in the rim and use a nipple from a basket ball and pump them up. but didn't know if it would help or make it worse.
Post by andymac0035 » Fri Aug 19, 2011 9:39 pm
Don't do that......that will make it worse, just strap the tires.
For something as powerfull as an e-revo, I would use more than one layer.
And yes, I'd balance them.
cher9498
Post by cher9498 » Sat Aug 20, 2011 12:14 am
andymac0035 wrote:Don't do that......that will make it worse, just strap the tires.
i checked out the straping vids. wow i did not think tape would make that much of a difference wow.
i am boiling my wheels now to try the strap method out then i need to build me a balancing stand then maybe i can drive this beast alittle better :twisted:
Post by andymac0035 » Sat Aug 20, 2011 12:50 am
If you have a spare stub axle, put that (without any halfshaft) onto either your revo or e-maxx and have it so that if you mount a tire on it it's up in the air so it spins freely. Instant balancer. I balance all my stuff with the front axle(s) of my rustler. Even works with little touring car tires.
