motor wiring question
ratpower396
Post by ratpower396 » Mon Jul 03, 2017 2:58 pm
Do most of you guys hardwire your motors to the esc or use using plugs? if plugs what type are you using??
matt1ptkn
Re: motor wiring question
Post by matt1ptkn » Mon Jul 03, 2017 3:24 pm
Back in the old days I used plugs, so that I could swap out motors easily. But I later realized that I was wasting a lot of plugs on motors and soldering/unsoldering wires really didn't take much time. Since then I have always hardwired. I'd say its really just a personal preference, but plugs could, on a rare occasion, come unplugged. ;)
-Matt
My Trucks
Post by SFC K » Mon Jul 03, 2017 5:31 pm
Plugs all the way. If you were a die hard racer, then hard wire the motor with no plugs in-between for less loss in current and more power to the motor. I'm not sure if it really helps or not but then again, I'm not a racer...
Post by andymac0035 » Mon Jul 03, 2017 10:25 pm
^^^ Oh it helps, I find myself hardwiring more and more...... it really does make a difference.
Almost everything I have is either hardwired or uses some kind of high-current connection.
Post by Sixtys Guy » Tue Jul 04, 2017 2:15 am
I don't hardwire..... On brushless I use the standard 3mm plugs. If they come with 4mm plugs I usually take them off and use 3mm plug as this is what most of my trucks use. On brushed I have actually just started using the same 3mm plugs as I use on the brushless motors. I never liked the standard bullet connectors, not sure why I didn't start doing this a long time ago!
Users browsing this forum: Google Adsense [Bot], rocpede and 3 guests
