starting my clod pounder
- Approved Member
this is what i am starting with.. Quite a nice box of parts.. I also picked up a pounder chassis, new bearings and all gears.
- Attachments
- DSC02627.1.jpg (76.8 KiB) Viewed 630 times
- Approved Member
Re: starting my clod pounder
added some summit links 3d printed upper and lower 4 link mounts and a fuel cell just for the heck of it after cleaning the gearbox and all new bearings and gears.
- Attachments
- DSC02628.1.jpg (254.95 KiB) Viewed 625 times
- Approved Member
added an axial transmission mount to strengthen up the lower chassis.
- Attachments
- DSC02630.1.jpg (207.46 KiB) Viewed 629 times
- Sixtys Guy
- Approved Member
Good one! I was really surprised at how easy it all fits together.
- Approved Member
coming together pretty easy so far. Just need to play with radio tray a little to not hit upper links and continue on the rear end. Then figure out suspension not sure if I want to try cantilevers from a revo or just go the standard shock set up..
- Approved Member
Front and rear gearboxes all mounted up with steering servo mounts and servos as well as the stock steering rods and pounder shocks for now.. Planning on putting traxxas shocks and custom rods.
- Sixtys Guy
- Approved Member
Looking good!
- Approved Member
After more work and forgot to take pics made a lot of progress. Printed beadlock wheels and a radio tray and mounted battery under tray with stock ground pounder battery cups. Installed radio gear, aluminum knuckles,homemade steering links and front servo saver. Electronics are Goolrc 27turn motors,arrma esc,Flysky radio,2s lipo,mg995 servos.
- Attachments
- front end1.jpg (111.98 KiB) Viewed 221 times
- Approved Member
- Approved Member
Working on body as we speak. Looking really good so far...
- andymac0035
- Administrator
Your going to hate getting that dirty since it's soooo clean.
- Approved Member
I will get over the dirt ... messing the body up might hurt more...
- Approved Member
A couple of body shots..
- Approved Member
- Approved Member
