SFC K Clod#3 build
SFC K Clod#3 build
Post by SFC K » Mon Apr 06, 2015 9:37 pm
Well, it has really been a while since I have tinkered on a Clod and a pair of axles just literally fell in my lap. Thanks to R Cane over on RC10talk.com. These were my prize for the guessing the RC wrapped in aluminum foil in the Fantastic Foil Contest over on RC10talk.
I have a couple ideas on what I want to do.
Either build a Super stocker, TXT-2, or WK chassis, I am leaning towards the WK idea or TXT-2.
Pictures to follow soon. :wink:
Re: SFC K Clod#3 build
Post by SFC K » Mon Apr 06, 2015 9:38 pm
Post by andymac0035 » Tue Apr 07, 2015 12:54 am
:popcorn: :popcorn: :popcorn:
Post by SFC K » Tue Apr 07, 2015 1:14 am
First gear case is apart. Already need to get an order in for a bearing kit. gears are in really great shape with minimal amount of grease for once. :lol: I will also be taking care of the steering nubs and grind the back of the hubs down for better steering.
Post by Justinswraps » Tue Apr 07, 2015 3:20 am
Lookin good Jeff 8)
Post by SFC K » Tue Apr 07, 2015 10:51 am
Thanks Justin!
Post by CowboyClod » Tue Apr 07, 2015 1:13 pm
Nice to see that you're finding time in working on these Jeff.
Post by GRAVETXT-1 » Tue Apr 07, 2015 7:31 pm
Ha! don't you mean TX-C2 or WK-C build :wink:
Post by SFC K » Tue Apr 07, 2015 8:18 pm
GRAVETXT-1 wrote:Ha! don't you mean TX-C2 or WK-C build :wink:
Well, I looked on the Bay and the TXT chassis are pretty much non-existent for the new Agrios chassis, but the WK-C, :mrgreen: are plentiful and cheap so I might just go WK-C. :wink:
Post by SFC K » Wed Apr 08, 2015 1:29 am
I finished tearing apart the other axle. I found one cracked hub so I placed in order with Brett from CPE for a set and bearing kit.
all parts are cleaned and ready for re-assembly. Now I am just waiting on the postman... :roll:
Post by SFC K » Mon Apr 27, 2015 10:46 pm
Interesting. I wonder if they come with any hardware or is it just the two plastic sides?
I had to wait for some parts for this as I was missing some 5mm "E" clips and the metal braces for the axle tubes. I also mounted rear steer lock outs I had laying around in the bin. New bearings were installed as well. I also had a TTR front steering kit on hand and started to install that. Is getting there now. I am going to go with center upper mount if the links can stay the same length but I need to decide on a chassis before I order anything.
I also shaved the hubs and the nubs off the axle tubes for better steering. I was going to use "C" stiffeners but the holes that were drilled do not match up with the ones I have from CPE so they will be staying in the parts bin unless I break a tube. :mrgreen:
I must say it sure is fun tinkering on these again. :wink:
Parts all cleaned up:
Post by SFC K » Tue Oct 20, 2015 11:50 pm
Finally took the plunge and picked up a WK chassis to get this build going again. :wink:
Post by GRAVETXT-1 » Wed Oct 21, 2015 12:06 pm
WK-C situation :P :P :P
Post by Diamond Dave » Sun Oct 25, 2015 1:55 am
Nice prize huh. We need to get that game going again.
Are you going to do anything special with this build? 4WS with 4 servos? All independent with a 8 or 12 channel radio? :lol:
Users browsing this forum: No registered users and 9 guests
