T2........ Judgement Day
Post by andymac0035 » Sun Jul 14, 2013 5:44 am
Uh-oh......... :o
Re: T2........ Judgement Day
Post by andymac0035 » Sun Jul 14, 2013 6:11 am
So whats going on here?.......
For those that don't know, I've had a Terminator before, and it was not all I had hoped it would be.
Sometimes I liked it.......and sometimes I hated it. At one point I actually swore-off TVP designs all-together.
But I've had an idea on the back burner for a while now.......
I was going to build my own chassis, and actually started it, but it didn't turn out so well, and I scrapped it.
I decided to take advantage of Brett's latest sale and pick up a center section complete with sway-bars installed. I actually went back and forth between terminator and predator, but i felt the terminator had better battery carrying options and adjustments.
This also coincided with doing a partial trade that got me some axles and other clod parts (and cash!) for my e-maxx.
So what's up?......... this terminator is going to have axle-mounted shocks!
No over stressing the links. They will be locating the axles only, not supporting the chassis.
Why?........ Because I like jumping, and I want to try getting some big air with this one.
It might be a racer, but it's going to live the life of a basher. :twisted:
So anyway, since this will be my 2nd Terminator.... I thought T2 would be a fitting name.
And this will be my final judgement on whether or not I can be happy with one. (maybe)...... :wink:
Post by andymac0035 » Sun Jul 14, 2013 6:21 am
So after the usual tear-down and checking over of the axles..... I got to work. :)
One of the first problems I tackled was shocks. I didn't have anything long enough to reach from the axle to the chassis. After many tries at trying to come up with some brackets I liked..... I decided to just make some shock extensions.
So what we have here are some dubro rod ends (CPE), one inch threaded studs (CPE), plastic from a chassis (scrap), all put on the end of GTR shocks from a traxxas JATO. The plastic bits were mounting posts from a broken rustler chassis. I just cut them out, drilled them through and cleaned them up with a dremel. Then covered it all with shrink tubing to try and make it look halfway decent.
I will probably buy some long shocks, but for now, these will work.
Post by andymac0035 » Sun Jul 14, 2013 6:41 am
So here it is starting to take shape:
Note that the wheelbase is NOT stretched with the use on the mounting plates.
The lower links are mounted in the usual spot.
The axles already had mounting plates on them, but the ones I had from CPE were a little smaller and mounted closer to the outer axle. I probably could have just swapped in the short CPE spacers....but meh.....
The longer spacers came in handy when I mounted the shocks (upper mount).
I also used conical washers liberally for spacers as well as additional clearance.
I didn't like the upper link mounts that came with the axles as well as the CPE set I had on hand, so those got swapped too.
Truck bottoms out on the shocks about a half inch before the chassis would slap, not sure if I like that or not......
Then again, with tire flex (deflation/compression on impact), it might be a wash......
The upper links are e-maxx tie rods with long/short ends to get the right length.
The lower links are a set of predator knurled links, Budhatrain...... these may look familiar. :wink:
Then I put some tubing on the swaybar ends and strapped them in place. I'm hoping the tubing will keep the zip-ties from sliding around.
Post by andymac0035 » Sun Jul 14, 2013 7:06 am
I was quite pleased with how the rear steer lock-out came out.
I'd seen this done before, but this one is adjustable on the fly. I used camber links from a rustler and an e-maxx tie rod. I wanted to put the short links under the supports, but they were just a tad to long for that. Worth noting is the use of conical washers here. This perfectly centers the bolt in the hole and keeps it from wandering.
Post by andymac0035 » Sun Jul 14, 2013 7:19 am
This truck will eventually have 550 e-revo motors in it. I had a single titan 12T handy (same size) and did a mock up.... and even with adjustable motor mounts.... it clears. This made me happy, as I want to gear this up eventually.
But for now..... silver cans and 13t pinions.
Not sure if it's shown in the pics to come but I put a set of those new CPE motor covers on it too. :)
My original steering set-up. I'm using the vertical servo mount. The short link was binding (hitting the servo). Too bad, as I liked it like this. I may possibly retry this with a bent tie-rod, but I liked the idea of using an adjustable camber link.
Post by andymac0035 » Sun Jul 14, 2013 7:36 am
Now here we have a piece of Clodtalk history!
That there is not just any 2WD slash RX box..... that is the RX and box that came out of the storied super-clod that I once had.... yes, I've held on to it all this time...waiting....
And on the other side we have an EVX-2 esc..... the new one..... with the lipo cut-off built in. :twisted:
With everything bolted to the side plates, the lower tray is free to hold a 2nd battery.
Borrowed the wheels and tires off the wraith-buster.... (I still need to get tires for this truck).
You can see here where I had to flip the servo upside down, moving the arm towards the bottom. I don't like that, but it's not binding anymore. I had a LOT of maxx rod ends and linkages to work with and they came in handy. I used many different combos of pivot balls and conical washers to get things placed just so.
This is really coming together now, but lots of adjustments will yet need to be made.
I am far from done.......very far.....
Post by andymac0035 » Sun Jul 14, 2013 7:47 am
It's alive!.......It's alive!....... MUAHAHAHAHAHA!!!!!!!! :twisted:
I was going to run both batteries lengthways, but didn't like the way the wires were on the bottom one, so instead of using 2 long straps I used 4 shorter ones.
Yes I broke the motors in first...... and yes I snuck outside @ midnight for a brief spin with it. No "kabooms!"........ yet..... :explosion:
Lots of suspension tuning ahead of me and alignment too..... front end needs some tow-out I think, and the rear might get towed in......we'll see.
Those shock extensions sure helped with wheel clearance when turning BTW...... makes me want to keep them. I think the pink-code springs might be too hard, might have to get some green-code springs.
Oh, and yes I have a body for it. I'm happy to say the wheelbase lines up too.
taz11
Post by taz11 » Sun Jul 14, 2013 10:51 am
Do you sleep?
LIKE
How long where you planning that? It takes me months to finish anything. You bang out a winner overnight. :mrgreen:
No space for shelf queens.....use it or loose it!
Powerram426hemi
Post by Powerram426hemi » Sun Jul 14, 2013 1:43 pm
Sweet Ride Andy!!! Cant wait to see how it performs and jumps with that shock setup!
Post by Justinswraps » Sun Jul 14, 2013 2:27 pm
That's what we like to see! Glad you decided to build one! Bring on the kabooms!!!!
Post by TamiyaTony » Sun Jul 14, 2013 2:40 pm
Looks good so far Andy. I feel this one can withstand most kabooms, so I wanna see her fly!
:D
Post by andymac0035 » Sun Jul 14, 2013 3:40 pm
taz11 wrote:Do you sleep?
LIKE
No...... I never sleep...... :lol: actually.... it's just that I work nights. :wink:
This was at least a month in the planning, but I've wanted to build a clod like this for well over a year. Ever since I sold off my last super clod I had been thinking about this concept, but was never sure of the best way to go about it, so I just put it out of my mind for a while.
As for whether it's a winner...... that is yet to be decided, but it does look promising.
Kingclod27
Post by Kingclod27 » Sun Jul 14, 2013 3:49 pm
Glad to see u with another Terminator!
SPEED.......I..AM..SPEED
Post by andymac0035 » Mon Jul 15, 2013 12:03 am
Got some runs in today. :)
I need to do some thread-locking of the chassis screws, but other than that, and a rod end on the rear lock-out.... no problems mechanically.
Tried 3S first.... then 4S. :twisted:
Truck handles the speed easily... could stand to be faster..... :explosion:
The silver cans took the 4S.... but the brushes are wearing already..... need to get some titan 550's soon.
I am a little concerned though..... as I was getting some intermittent cutting out of the power.
So I'm hoping it's the cheap/crappy motor wires, and not the esc or batteries.
Vid is up!
[youtube]cRtS1ZeQfS0[/youtube]
Users browsing this forum: Bing [Bot] and 8 guests
