Clodbuster/TXT 19MM Wheel Hex Set
Post by SFC K » Tue Feb 09, 2016 2:47 pm
Brett,
Do you happen to have a picture of Clod 19mm Hex Kyosho wheel adapters for a clod with the wheels mounted? I'm having trouble finding the RC4WD 12mm-19mm adapters so I will be purchasing the ones you have on your site. I'm just curious how the USA 1 wheel sits on the axle and if I need to use any specific washer? the hole in the rim is larger than the 6mm stub axle.
http://crawfordperformanceengineering.c ... cts_id=563
Thanks,
Re: Clodbuster/TXT 19MM Wheel Hex Set
Post by cpe mt » Wed Feb 10, 2016 5:05 am
I do not. When I used the 12-19mm adapters on a truck, I used a fender washer to rest between the wheel nut and the recess in the wheel. Thanks!
Post by SFC K » Wed Feb 10, 2016 12:09 pm
Thanks for the reply Brett! I will be ordering a set and will post pictures here for others to see. It seems these wheels are popping up again. :wink:
Post by SFC K » Fri Feb 12, 2016 2:37 pm
Just ordered a set Brett! :wink:
Thanks!
Post by cpe mt » Wed Feb 17, 2016 4:24 am
Thanks! It shipped out earlier today.
Post by SFC K » Fri Feb 26, 2016 2:56 am
Thanks Brett! I will post some pictures of them mounted on the axles once I get a minute to mess with them.
Post by SFC K » Sun Mar 20, 2016 9:23 pm
I finally messed around with these 19mm wheel hex's. They work well and require a few washers on the rim side for the wheel hex to fit snug. They do offer a bit more width than the stock clod wheel (Duratrax spike tires) does.
I know these wheels and tires are not that common, but incase you find a pair, their is a way to mount them to Clod axles.
Users browsing this forum: Yahoo [Bot] and 1 guest
