Wraith Clodbuster/TXT Wheel Hub Adapters
Awesome Kong84
Post by Awesome Kong84 » Fri Sep 11, 2015 7:12 pm
I have been noticing some members on here and other forums having issues with these adapters in particular the M4 screws. On your site you recommend using the blue loctite. Even when using it there are still issues with the screws not being long enough or so I read. Has there been a change in the design to remedy this issue or longer screws are now coming with the adapters? I have a set which I am putting on my AR60s very soon and just curious as to if I would be running into similar issues?
Thanks in advance
Re: Wraith Clodbuster/TXT Wheel Hub Adapters
Post by cpe mt » Sat Sep 12, 2015 12:07 am
We went from 6mm to 8mm long hardware a while back. Going further to 10mm let the bolts bottom out before they were fully seated which left the wheel loose.
