CVDs. Anybody running them?
Tug4090
Post by Tug4090 » Mon Dec 15, 2014 1:48 am
There a little set screw that holds the drive pin in them. I've retightened them over and over but after one run the pin comes out. What are you all doing to keep them in?
Re: CVDs. Anybody running them?
Post by Justinswraps » Mon Dec 15, 2014 2:06 am
Blue loctite
Tug4090
Post by Tug4090 » Mon Dec 15, 2014 2:12 am
Should I put a little on the pin itself too?
Post by cpe mt » Mon Dec 15, 2014 2:38 am
We haven't really heard of any issues with those, but I don't believe they're loctited at the factory. Blue loctite will work, and for where that setscrew is, red probably would too since it's not something you're typically going to remove. The pin won't need anything on it, although putting a piece or heat shrink tubing over it will keep it from falling out. Thanks!
