CPE NONBEAD Clod wheelset questions
Post by GRAVETXT-1 » Tue Oct 28, 2014 3:23 pm
Hi Brett :) before I blow 80 dollars on a set was wondering;
5/8" offset built into the wheels :thumbsup: is that a similar increase in width that I have on my FOTD truck with Thundertech 1/4" 32mm wideners installed? Maths was never my strong point lol.
With your custom wheels being narrower will Clod tyres "bulge" much? What I am trying to say is can you post some photos with Clod tyres installed on the wheels?
I fancy a green set :mrgreen:
EDIT; also I do not want to glue the tyres on how well will the tyres fit DRY fitted?
Re: CPE NONBEAD Clod wheelset questions
Post by SFC K » Tue Oct 28, 2014 5:10 pm
I totally forgot Brett made these. I'm glad you brought this back up. I could use a set for my Barbarian build.
Post by GRAVETXT-1 » Thu Oct 30, 2014 8:32 pm
Ok its BUMP time does anyone have personal experience with these wheels?
Someone on Clodtalk must have bought a set? :popcorn:
Post by cpe mt » Thu Oct 30, 2014 11:39 pm
Sorry, been working on trying to catch up on orders still. Width is going to be slightly wider than your 1/4" offset wideners.
I don't have a photo of those wheels with stock Clod tires on them, but the aren't going to curl in a lot. These wheels are only around a 1/4" narrower than a stock Clod wheel. The bead diameters are the same as stock wheels, so the tires should hold well. Adding the rubber band to the beads would work on these as well. Thanks!
Post by GRAVETXT-1 » Fri Oct 31, 2014 3:27 pm
Thank you for the reply am getting more tempted :P 5/8" offset sounds a bit too wide for FOTD is it possible you could make me a custom set with 1/4" offset instead?
Post by GRAVETXT-1 » Fri Nov 07, 2014 4:02 pm
Brett your non bead wheels have gone off your website are they no longer available for sale?
Post by cpe mt » Fri Nov 07, 2014 6:32 pm
We're trying to catch up on beadlock wheel orders, which take just under 40 hours per set to print. Once we do, both types wheels will be back available. Thanks!
Post by GRAVETXT-1 » Fri Nov 07, 2014 7:52 pm
Awesome thanks for quick reply :P
Post by cpe mt » Wed Nov 12, 2014 11:37 pm
Both our beadlock and non-beadlock wheels are back available on the website!
Post by GRAVETXT-1 » Thu Nov 13, 2014 2:56 pm
cpe mt wrote:Both our beadlock and non-beadlock wheels are back available on the website!
Just ordered a set :P here's hoping I wont be disappointed Brett! :popcorn:
