Clodbuster CVD/XVD Axles!
Post by cpe mt » Tue Jun 10, 2014 3:43 pm
Clodbuster XVD axles available for presale now! We'll have our order of new Clodbuster XVD axles in-house next week, and these are sure to sell out fast. Purchase from us and receive the correct 12mm aluminum drive hexes as well! Sold in sets as pictured, so you will need to purchase 2 sets to complete a single truck.
http://www.crawfordperformanceengineeri ... cts_id=714
TynClodMan
Re: Clodbuster CVD/XVD Axles!
Post by TynClodMan » Sun Jul 06, 2014 5:13 am
Pounded away tonight trying to get these in my clod axels but for the life of me I can't get the steering knuckle on. The holes for the kingpins won't line up. It's like the XVD is keeping the knuckle about 1-2 mm out of position.
From inside gearbox out
Axle - e clip - washer - bearing - bearing - washer -XVD - knuckle with new supplied bearings installed
Can you tell me if this is the correct setup. I couldn't find any instructions
Thanks for the assistance.
Post by cpe mt » Sun Jul 06, 2014 11:57 pm
That's correct, and you may actually be seeing a stack up of tolerances pushing the axle too far out for the knuckle to install. We had them available for the older TTR CVD's as direct replacements, but we offer a 3.5mm wide bearing in place of the 4mm wide ones that come with the RC4WD kit. I'm willing to bet using those in place of the supplied ones will fix your issue...
http://www.crawfordperformanceengineeri ... cts_id=721
TynClodMan
Post by TynClodMan » Wed Jul 09, 2014 3:47 am
Cool thanks for the info Brett. I got my bearings off eBay so I'll pull them out and measure them up.
If they are 4 mm would I be able to remove the last washer between the earring and the XVD or is that a bad idea to have the XVD rubbing direct on the bearing?
Thanks again for your help, I'm really excited to get these going!
Cheers
TynClodMan
Post by TynClodMan » Wed Jul 09, 2014 3:55 am
Ah my bad I just retread your post and looked at the kit and bearings. Your talking about the bearings in the steering knuckle that come with the XVDs . They are 4mm gotcha. So buying the other ones off you, the 3.5mm to replace those should fix the issue. Bingo! I'll fire up an order tomorrow as the clod looks depressed sitting on the bench with no front end.
Cheers man
rknaub
Post by rknaub » Tue Sep 09, 2014 11:57 pm
So do these add any width? Will they work with the integy knuckles? Do they work with CPE wideners?
Post by cpe mt » Wed Sep 10, 2014 1:43 pm
These will add approximately 1/4" per side, and they'll work with stock or aftermarket knuckles. You can use them with our wideners, but you'll need to use a longer M5 bolt to tighten down everything than the ones supplied in the XVD bag. Thanks!
rknaub
Post by rknaub » Wed Sep 10, 2014 1:54 pm
Awesome, thanks again!
