What turns are your servos
CLODZ_72_2003
Post by CLODZ_72_2003 » Sun May 04, 2014 10:11 pm
Looking to upgrade to aluminum servo arms for my CPE servo.....found out servos have different turns that would allow different aluminum arms to be used....23t 24t 25t
What turns are yours?
Thanks Brett
Alfy
You crawl with 4, But I drive with 18 :wink:
slapshot1979
Re: What turns are your servos
Post by slapshot1979 » Mon May 05, 2014 12:17 am
turns or teeth on spline? never heard of the servo having a turn rating only oz. torque and speed.
CLODZ_72_2003
Post by CLODZ_72_2003 » Mon May 05, 2014 12:28 am
I'm guessing t stands for turn, the axial aluminum servo horn comes in those 3 options
slapshot1979
Post by slapshot1979 » Mon May 05, 2014 12:32 am
No thats the number of teeth on the servo output shaft.
slapshot1979
Post by slapshot1979 » Mon May 05, 2014 12:34 am
They are spline drives so there are 3 different sizes ...Why they cant all get along and make one frigin size is beyond me, but been that way for ever and ever. normally your servo manufacture will have the specs on spline size
CLODZ_72_2003
Post by CLODZ_72_2003 » Mon May 05, 2014 12:55 am
CPE website says standard futuba spline.... Looks like standard spline is 25, so I just learned something new and my answer
slapshot1979
Post by slapshot1979 » Mon May 05, 2014 1:00 am
Futaba 25 Teeth seems to be the most common that Ive run into anyways.
Post by cpe mt » Mon May 05, 2014 1:21 am
Yes, our servos are 25T (25 spline), which matches the Futaba splined arms. Most all RTR servos and "off brand" servos also use a 25T spline. Thanks!
CLODZ_72_2003
Post by CLODZ_72_2003 » Mon May 05, 2014 2:05 am
Thank You Both!
Alfy
