Barbarian is here!
Re: Barbarian is here!
Post by cpe mt » Thu Nov 28, 2013 6:25 pm
We currently have plenty of Barbarian chassis in stock, and we've just introduced our new sway kit to go with it! These are designed using hi-strength 0.125" dia spring steel to minimize torque twist.
http://www.crawfordperformanceengineeri ... cts_id=671
Post by SFC K » Fri Nov 29, 2013 12:52 am
Nice Brett and just in time. I am going to be ordering the chassis soon. I will have to add this to the list.
I take it those will work on the stock AX-10 axles as well? Just mount on the outside edge of the shock mounts? Also because the torque twist is predominantly in the rear do you think a kit would be needed for the front as well?
Post by cpe mt » Fri Nov 29, 2013 1:45 am
I don't have AX10 axles here, but as long as the shock mount spacing is the same as a Wraith these should work. This kit actually includes front AND rear sway bars, they're just both the same design so I only took a photo of the rear axle layout. Personally, I'd run bars on the front and rear as running a front bar will help entering and exiting a corner.
Post by SFC K » Fri Nov 29, 2013 2:31 am
That is great that it comes with both! Thanks for the helpful info! 8)
Post by cpe mt » Thu Dec 05, 2013 5:15 pm
Figured I'd post a couple completed Barbarian shots. These chassis are selling fast and there are a bunch of build threads available here to review.
Post by cpe mt » Fri Dec 13, 2013 4:03 pm
We currently only have 5 Barbarian chassis remaining from our last order. These are the last 5 available before these see a slight price increase, so get yours now in time for the holidays!
http://www.crawfordperformanceengineeri ... cts_id=655
Post by cpe mt » Wed Dec 18, 2013 3:23 pm
Barbarian chassis have been flying out the door! We are currently sold out of these chassis, with the next batch scheduled to arrive on 12/28. The new batch will have a revised base price of $99.99. From now through the 28th, pre-order yours at the original $89.99 price!
Post by SFC K » Wed Jan 01, 2014 3:48 pm
I just order the chassis and sway bar kit! Thanks Brett!
Post by SFC K » Tue Jan 14, 2014 12:46 pm
Brett,
FYI, With the use of the AX-10 axles the stock upper links are about 1 inch too short.
I should add the stock straight lower links are just the right length. I am mounting mine on the outer hole on the chassis. With the AX-10 axles I also have to mount the sway bar kit on the inside of the shock do to mount limitations on the axles. I think this will work. I will post a picture tonight when I get home to show everyone what I mean.
Thanks, Jeff
Tug4090
Post by Tug4090 » Sun Jan 19, 2014 6:20 am
Brett,
Sent you a PM about the chassis kit and all the accessories on order from you about two weeks ago. I haven't seen it come yet, just wanted to make sure everything was OK with it.
Thanks,
Tug Brock, Milford Ohio
513-748-4586
Post by Justinswraps » Sun Jan 19, 2014 6:28 am
Brett runs a ton of Monster Jam shows during this time of year. So catching him can be a little trickey sometimes. Just bare with him a bit. He's a great guy and has great products
FlashGordon1
Post by FlashGordon1 » Sun May 18, 2014 3:38 am
Could this chassis work on a set of clod axles :? [-o< :-k ?
Post by cpe mt » Sun May 18, 2014 2:52 pm
FlashGordon1 wrote:Could this chassis work on a set of clod axles?
Not very easily. We designed this chassis around using Axial Wraith axles.
FlashGordon1
Post by FlashGordon1 » Sun May 18, 2014 6:23 pm
l would like to thank you for answering my question. Don't want to force something that would not fit.
