Barbarian is here!
Re: Barbarian is here!
Post by cpe mt » Sat Sep 14, 2013 3:18 am
Barbarian is here! This is the 1st race-specific chassis designed around using the Axial Wraith driveline. The wheelbase as pictured below is 13", using all of the stock upper/lower Axial 4-links. Check out the full specs on our website, and don't miss out on a great introductory offer!
http://www.crawfordperformanceengineeri ... cts_id=655
Post by vwjuice » Sat Sep 14, 2013 3:27 am
That looks sweet Brett. Amazing job yet again.
Post by cpe mt » Thu Oct 10, 2013 9:04 pm
These chassis are now shipping out! These will arrive fully assembled ready to accept your Wraith driveline and suspension. Bare chassis pics are below. Order yours here: http://www.crawfordperformanceengineeri ... cts_id=655
clodsrfun
Post by clodsrfun » Fri Oct 11, 2013 12:09 pm
Awesome work CPE! Hmmmm i have a set of built wraith axles waiting on a build.
Chuck Norris and Mr. T walked into a bar. The bar was instantly destroyed, as that level of awesome cannot be contained in one building.
Post by cpe mt » Sat Oct 19, 2013 12:46 am
We're now offering aluminum upper/lower 4-link kits designed specifically for the Barbarian chassis. These are the same length as the stock Axial links, and will give your chassis between a 13" and 13-1/2" wheelbase.
http://www.crawfordperformanceengineeri ... cts_id=661
Post by cpe mt » Tue Nov 05, 2013 2:34 pm
Picked up our 2nd run of chassis yesterday, and most of this order has already sold out as well. Think we only have 2 chassis remaining. Our free shipping offer ends today on these!
Post by CowboyClod » Thu Nov 07, 2013 2:07 pm
I have a good question. Would there be any issues getting the stock Clod gear case with it axel tubes onto this chassis?
Re: Coming Soon!
Post by andymac0035 » Thu Nov 07, 2013 3:33 pm
cpe mt wrote:I never laid Clod axles under it, but I'd expect some of the cross braces will be in the way. This chassis was designed specifically around using the Axial driveline in it.
Spidubic
Post by Spidubic » Thu Nov 07, 2013 3:55 pm
This chassis is soooooo tempting. I have a Wraith that sits on the shelf collecting dust. It is built with a Holmes Hobbies ESC and 13T Crawler motor which is great for climbing over stuff but a little slow. I may see about dropping a faster motor into it and see if that makes me use it more. Beyond that putting the axles under this chassis and turning it into a monster may be my next option.
Super Clod, Mod Clod, Double K Clod, Bullhead Tow Truck, Groundpounder Bigfoot
Re: Coming Soon!
Post by CowboyClod » Thu Nov 07, 2013 4:07 pm
Okay thanks Andy. After seeing what Spidubic did with his KK chassis I figured it would be possible to do the same thing with the Barbarian chassis.
Post by cpe mt » Thu Nov 07, 2013 6:32 pm
Your best bet if you wanted to go with Clod axles would be to use a 4-link mounting layout like the ESP chassis use. That way you can eliminate the upper 4-link mount, and the high-mounted upper links. Doing that, you MAY only need to move/modify the outermost chassis brace on each end.
Zac_F85
Post by Zac_F85 » Sat Nov 09, 2013 8:01 pm
@$40 shipped that is a great deal on a nice looking chassis.. to bad a decent wraith is $300 or so haha Would you ever consider making shorter links to make a short wheelbase setup? like 11"-12"?
Maybe a Clod axled version should be made? As those (clod axles) can be made up for around $100 less with tires/wheels..
Post by andymac0035 » Sat Nov 09, 2013 11:57 pm
You do realise you don't need a whole wraith right?
Hit the ebay chop-shops for axles/tranny/driveshafts.
Post by CowboyClod » Sun Nov 10, 2013 2:39 am
I don't need Clod axels as I can use one of my Clods as a donor if I decided to go this route.
Also I can shoot up Wraith axels at Epay.
http://www.ebay.com/itm/NEW-Axial-Wrait ... 1e825309c3
Post by cpe mt » Mon Nov 11, 2013 3:42 pm
Zac_F85 wrote:Would you ever consider making shorter links to make a short wheelbase setup? like 11"-12"?
We could do shorter links no problem, but you'd need to be careful with the angle of the shocks from the axles to the chassis.
