Barbarian is here!
Barbarian is here!
Post by cpe mt » Sun Sep 01, 2013 12:18 am
Coming in mid-September - Barbarian!
todd ritchings
Re: Coming Soon!
Post by todd ritchings » Sun Sep 01, 2013 1:08 am
You have to give us a bit more Brett!!!!!!!!!!!!!
Re: Coming Soon!
Post by SFC K » Sun Sep 01, 2013 1:53 am
todd ritchings wrote:You have to give us a bit more Brett!!!!!!!!!!!!!
X2 :D
Re: Coming Soon!
Post by charliechristmas58 » Sun Sep 01, 2013 4:46 am
He told you that "The BARBARIAN" is coming this mid september. Its a new chassis :D
Re: Coming Soon!
Post by cpe mt » Fri Sep 13, 2013 2:14 am
Here's a shot of the 1st Barbarian chassis plate off the laser cutter! This will be a full-length, CRD styled chassis designed around the Axial Wraith driveline. Plates are a full 1/8" thick, and will be set up for around a 13" WB. Additional information, photos, and pricing/presale coming soon to the website!
Re: Coming Soon!
Post by vwjuice » Fri Sep 13, 2013 2:16 am
Is that a crawler type chassis? It looks cool.
Re: Coming Soon!
Post by cpe mt » Fri Sep 13, 2013 2:33 am
No, it's a race chassis. Loosely designed to look like the lower half of the full-size CRD chassis used in Monster Jam.
Re: Coming Soon!
Post by vwjuice » Fri Sep 13, 2013 2:39 am
Oh that's sweet. It should work with clod axles as well won't it?
Re: Coming Soon!
Post by cpe mt » Fri Sep 13, 2013 2:46 am
I never laid Clod axles under it, but I'd expect some of the cross braces will be in the way. This chassis was designed specifically around using the Axial driveline in it.
Re: Coming Soon!
Post by vwjuice » Fri Sep 13, 2013 2:59 am
Well it looks sweet. I might have to finally build an Axial truck.
Re: Coming Soon!
Post by Budhatrain » Fri Sep 13, 2013 4:30 am
something I thought looked good is beveled edges on the plates. When powder coated it almost looks tubeish...
just a thought
Re: Coming Soon!
Post by andymac0035 » Fri Sep 13, 2013 6:56 am
vwjuice wrote:Oh that's sweet. It should work with clod axles as well won't it?
I've got to admit.... that was my first thought too....
Well I hope someone lays some clod axles under it, because I'm curious now.
Re: Coming Soon!
Post by SFC K » Fri Sep 13, 2013 11:52 am
I have some AX10 axls and drive train I could use on this... I like it! Does the AX-10 transmission plate line up with the holes on the bottom?
Re: Coming Soon!
Post by cpe mt » Fri Sep 13, 2013 12:36 pm
SFC K wrote:I have some AX10 axls and drive train I could use on this... I like it! Does the AX-10 transmission plate line up with the holes on the bottom?
Yes. We made the trans plate with holes for both the Wraith and AX10 style transmissions to install.
Re: Coming Soon!
Post by SFC K » Fri Sep 13, 2013 3:10 pm
Very cool Brett! 8)
