| Author |
Message |
orcusomega
Approved
Morning Clod Gods  I am in the middle of my Racer project, and I am getting very frustrated with the truck's turning radius (or lack thereof) There HAS to be a way to make this thing turn tighter - I am already using a high torque servo (HS-645MG) with it mounted on the gearbox (see my other post about the plates I whipped up). I would prefer not to have to run rear-steer, but it looks like it may be the only option! So what have you done to improve this? Could you post pics please? Thanks! Bob
| Thu May 06, 2010 2:18 pm |
Site Admin
Joined: Wed Feb 18, 2004 1:40 am Posts: 2646 Location: Southern California
Grind off the steering stops. This helps a lot.
_________________ Scott T
| Thu May 06, 2010 3:40 pm |
orcusomega
Approved
Thanks, I did this already - the problem is exacerbated by the fact that I am stretched quite a bit - I am running the Clodzilla IV chassis, plus the links are attached to plates that stretch t some more. How about extensions? I have been thinking about higher-clearance knuckles and tubes - but I need this done NLT next week  (sorry, this pic is of the rear where the steering is locked out). Bob
| Thu May 06, 2010 4:09 pm |
1of1547
132NHAF wrote: Grind off the steering stops. This helps a lot. Which stops, the ones on the hub or axle?
_________________ Original Clod Buster that is in a resto-mod restoration
| Thu May 06, 2010 4:38 pm |
orcusomega
Approved
Oh, good point (another forehead slapper). I worked on the hubs, i'll check the axles when i get home.
Bob
| Thu May 06, 2010 4:52 pm |
Pit Crew
Joined: Wed Sep 30, 2009 1:42 am Posts: 4022 Location: Back in MN!
Look here...I did the mod to my truck with pictures and get pretty darn good steering out of mine now... viewtopic.php?f=9&t=22529&start=30
_________________ Wait for it!
| Fri May 07, 2010 12:20 am |
Site Admin
1of1547 wrote: 132NHAF wrote: Grind off the steering stops. This helps a lot. Which stops, the ones on the hub or axle? Both.
| Fri May 07, 2010 2:50 pm |
1of1547
Cool thanks, is it a big improvement over stock?
| Mon May 10, 2010 4:36 pm |
Site Admin
Huge. Of course I'm still running four-wheel-steering so it's really great.
| Mon May 10, 2010 8:30 pm |
FlashGordon1
Life Saver
Joined: Sat Jan 10, 2009 3:21 am Posts: 2468 Location: Buffalo,New York
orcusomega wrote: Thanks, I did this already - the problem is exacerbated by the fact that I am stretched quite a bit - I am running the Clodzilla IV chassis, plus the links are attached to plates that stretch t some more. How about extensions? I have been thinking about higher-clearance knuckles and tubes - but I need this done NLT next week  (sorry, this pic is of the rear where the steering is locked out). Bob It has been a few months,do you have any updates?
_________________ SOLID AXLE SHAFT MONSTER TRUCK'S http://www.facebook.com/groups/228629583892520/
| Mon Sep 20, 2010 11:52 pm |
Approved
Joined: Mon Jun 29, 2009 12:52 am Posts: 1660 Location: Ohio, USA
The turn radius is radically improved if you do both the hubs and axle.
However- something to ask this crawler guy back when he asked would have been if he locked the axles- that would have been a big reason the turn radius is poor. Locked hubs limit steering- some people lock the rear and then put a thicker diff grease in the front. Just saying!
_________________Team Driver for 2 great companies, visit www.cowrc.com and http://store.rc4wd.com/
| Tue Sep 21, 2010 12:06 am |
Merrixs
I can not verify this, but in theory a behind the axle setup might help. It will help with slower speed turning anyway.
| Thu Sep 30, 2010 5:15 pm |
orcusomega
Approved
Sorry gents, life has been crazy  The high clear and knuckles and outers helped, but ironically they are also restrictive given the layout of the arm itself  . My axles are not locked, but the steering throw I was hoping to gain with the high clearance knuckles has not improved it much - I will try to get pics (I am writing this while on line at the mall lolol) Bob
| Thu Sep 30, 2010 5:27 pm |
FlashGordon1
Life Saver
| Sat Oct 02, 2010 4:25 am |
