New Potential Monster - HSP
Post by Sixtys Guy » Wed May 24, 2017 10:32 am
Found this flicking through ebay today... looks like a Wraith style rig. No idea what it would be like, but it looks cool!
"RGT Racing is Please to announce of the releasing the all new RR-4. The vehicle design idea is from the popular full scale Hammer Rock Racing concepts with the full size all plastic tube roll cage to enhance the realistic feels and scale looks. It also has the realistic drivers mounted with decorated cockpit. As for the performance, the vehicle has Multilink suspension and full lock front and rear axle. It also has rigid high aluminum chassis and 2.2 inch high performance tires and wheel set for maximum rock racing performance
Specificstiom:
lenght:480mm Width:280mm
Height:210mm Wheelbase:350mm
Ground clearance:84mm Weight:2800grm
wheel diamete:54mm(2.2inch) Tire diameter:140mm
Radio System:2.4ghz Esc:Waterproof 45A 2in1 esc
Servo:Waterproof 9KG Battery:7.2V 2000mah nimh
Motor:Brushed rc540 Gear ratio:1:48
Low Center Gravity (LCG) design of the transmission gear, electronics and battery tray !! This will provide better crawling performance !
The vehicle has ground clearance up to 84mm for extreme rock crawling performance.
Low Center Gravity battery compartment and Electronics setup !! In order to have all round performance and speed, the new design allowed the hobbyist customize the battery to mounted front or rear without any optional parts."
s-l1600 (1).jpg (202.05 KiB) Viewed 582 times
s-l1600 (2).jpg (187.78 KiB) Viewed 582 times
s-l1600 (3).jpg (248.59 KiB) Viewed 582 times
s-l1600 (4).jpg (206.05 KiB) Viewed 582 times
s-l1600 (7).jpg (216.95 KiB) Viewed 582 times
s-l1600 (5).jpg (199.69 KiB) Viewed 582 times
s-l1600 (6).jpg (250.46 KiB) Viewed 582 times
s-l1600 (8).jpg (235.44 KiB) Viewed 582 times
ratpower396
Re: New Potential Monster - HSP
Post by ratpower396 » Wed May 24, 2017 11:22 am
wonder what wraith parts if any will fit???
Post by Sixtys Guy » Wed May 24, 2017 11:59 am
I did wonder that....
ratpower396
Post by ratpower396 » Wed May 24, 2017 3:03 pm
axles and gearbox look identical to the everest 10 axles and gearbox. If so then axial upgrades will work.
Post by andymac0035 » Wed May 24, 2017 3:11 pm
Interesting, looks more in line with the old AX10, but I can't help laughing at the rear driveshaft hanging in pic #3.... :lol:
ratpower396
Post by ratpower396 » Wed May 24, 2017 6:53 pm
maybe a pre production model...lol
Post by Sixtys Guy » Wed May 24, 2017 8:15 pm
That would be promising.
Post by Sixtys Guy » Wed May 24, 2017 8:16 pm
Good pickup!
darat76
Post by darat76 » Fri May 26, 2017 2:07 pm
that's the newly developed air drive system, true 100% power transfer regardless of angles....
The Knight
Post by The Knight » Fri May 26, 2017 4:38 pm
Thats the evolution of the old HSP pangolin. Same axles I see.
Greets from Germany!
The Blackfoot III
Post by Sixtys Guy » Fri May 26, 2017 11:49 pm
I didn't realise that, but yeh looks to be the same running gear. I think that then means it's basically a AX10 copy?
The Knight
Post by The Knight » Sat May 27, 2017 6:05 am
Yes and no. It's a copy in this way. But parts are not 100% compatible. Axle housing is completly other and the gear in the middle have another gearbox. Some alloy parts fit, others not.... I tried to upgrade an Pangolin gear to an Axial gear and stopped it.
The Blackfoot III
Busby
Post by Busby » Wed Jun 07, 2017 1:40 pm
I didn't realise that, but yeh looks like metadrol the same running gear. I think that then means it's basically a AX10 copy?
I like the looks of this one.
Post by Sixtys Guy » Thu Jun 08, 2017 2:01 am
Yeh i do too, looks like a budget Wraith.
Post by Halgar » Thu Jun 08, 2017 5:36 am
I saw that too. Those drivelines won't last either, plastic is too soft causing the knuckles wear out extremely fast.
