Jconcepts Tribute wheels and tire comparison
TweakedTad
Re: Jconcepts Tribute wheels and tire comparison
Post by TweakedTad » Tue Jan 03, 2017 10:38 pm
The wheels are just slightly smaller than stock. I have glued stock tires to the wheels with no problems. I would just leave the tires off for a few days and see if the go back to stock shape.
You will need to glue these like most newer tires. They are soft and will not stay on the rims if you don't. My stock tires never stayed on after I started running anything over a stock motor.
GodsLiLMistake
Post by GodsLiLMistake » Sun Jan 08, 2017 7:41 pm
http://shpws.me/Nd5s
Found this on shapeways if anyone is interested
TweakedTad
Post by TweakedTad » Wed Jan 11, 2017 5:28 am
They added a nice new bright color to the tribute wheel selection.
The Knight
Post by The Knight » Thu Jan 12, 2017 1:21 pm
Is it neon or true yellow? Looks like neon-yellow...
Greets from Germany!
The Blackfoot III
TweakedTad
Post by TweakedTad » Thu Jan 12, 2017 2:32 pm
Yes it is a neon yellow like there race wheels.
GodsLiLMistake
Post by GodsLiLMistake » Thu Jan 12, 2017 6:52 pm
I picked up a set of black and a set of gray ones wheels i thought they should look good with my MM body. what is your thought about the Tires? how are they lasting to the abuse that they see from these big trucks? what about compound that they come in (soft could be softer or other way around)? anyone custom cut one yet? try to make it hook up better?
TweakedTad
Post by TweakedTad » Thu Jan 12, 2017 7:15 pm
They are holding up and working great. I run gold on carpet and the blue on dirt and concrete. No need for modification they hook up nicely..
The black wheels look nice with my MM body.
GodsLiLMistake
Post by GodsLiLMistake » Sat Jan 14, 2017 5:08 pm
I just got my wheels and tires in and they look great, i put the black center caps on the gray wheels and the gray center caps on the black wheels i think they look great and the med compound tires are a little harder then i thought they would be
Post by GRAVETXT-1 » Sat Jan 28, 2017 2:28 pm
Any chance they will release a neon green set of wheels? They will look amazing with the design I have in mind with my retro build.
15894791_1550240358326574_2043071799816135654_n (Small).jpg (47.53 KiB) Viewed 697 times
TweakedTad
Post by TweakedTad » Sun Jan 29, 2017 3:17 am
There isn't any plans to offer green but you never know. This was a color they use on there off road wheels so they already had it to use for a option.
80's MonsterMan
Post by 80's MonsterMan » Thu Feb 02, 2017 8:51 pm
Great write up Tad, got my first set tires in today other 2 coming separate for some reasn. Man after seeing in person these tires are spot on late 80's just love the look of them look perfect on my Digger build.
Also I see what you were saying on the dia. of JC wheels vs the stock Clod. Think I might get a set of the wheels, as it does look better imo with the smaller dia. wheels and like you said on the width as well. Gives it that realistic bulge of the tire.
GodsLiLMistake
Post by GodsLiLMistake » Fri Feb 24, 2017 11:16 am
Just wondering has anyone cut or modified the foams in the tires? How do you get the white foam to not bunch up when installing the tires on rims?
Post by KONG » Tue Mar 07, 2017 1:27 am
Users browsing this forum: No registered users and 16 guests
