Gear Reduction Units
The_Bishop
Post by The_Bishop » Thu Feb 26, 2004 12:51 am
Is there anything on the calendar to suggest that these will be manufactured again?
Thunder VP
Post by Thunder VP » Thu Feb 26, 2004 4:33 am
I'm sure we will bring them back again at some point. No date set though.
The_Bishop
Post by The_Bishop » Thu Feb 26, 2004 6:04 pm
I just figured I'd ask because there certainly does seem to be a market for them.
Thunder VP
Post by Thunder VP » Sat May 08, 2004 5:32 pm
Due to popular request we will be bringing back the 7:1 reduction unit.
A small limited production run should be ready to ship around May 13th or so.
If you have been looking for a set act quickly as it is a limited run.
We are also working to producing a smaller 3 or 4 to 1 unit that should be ready by late summer.
Kona_Joe
Post by Kona_Joe » Tue May 11, 2004 11:18 pm
Thanks Again!
Called and placed my order today. :D
Joe
jaapzuki
pinion gears
Post by jaapzuki » Sun Sep 12, 2004 1:40 am
so what pinion gears are you guys using in the 7:1 reduction unit
and what is the gear ratio stock clod gears and 9 tooth pinion
Thunder VP
Post by Thunder VP » Mon Sep 13, 2004 4:58 am
Clod with 9 tooth pinion would be 43.46:1
Using the gear reduction can give a range between: 53:1 to 268:1
So its up to you depending on how much power or how slow you want to go.
bbytraction
Re: Gear Reduction Units
Post by bbytraction » Sat Feb 07, 2009 3:38 am
yes i'll get a set of 4 to 1 posted big when it come out.
that one push crush rock like snow before feading time ..thats plow #1 at 11.1/2in wide.
bbytraction
Post by bbytraction » Sat Feb 07, 2009 3:42 am
9 tooth on 4to1 what wood be the ratio # :?: thank you
Thunder VP
Post by Thunder VP » Tue Feb 10, 2009 4:49 am
Although they are no longer available here's a link to the old 7 to 1 web page. It has a gear ratio chart at the bottom.
http://www.thundertechracing.com/7to1.htm
