Wheely King Clod wheel adapter question
Support forum for Thunder Tech Racing.
http://www.thundertechracing.com/
Moderators: Thunder Tech Pres., Thunder VP
Post by GRAVETXT-1 » Thu Aug 18, 2016 8:47 pm
My tiny brain is confused which Thunder Tech adapter do I need to get so I can install Clod wheels on Wheely King axles?
Which part number please.
Grim Reaper, Valhalla, Ford Of The Dead, Kings Bounty, Gauntlet, Gauntlet # 2, Clawing Dead
Re: Wheely King Clod wheel adapter question
Post by CowboyClod » Sun Aug 21, 2016 6:43 pm
You can get Wheely King Clodbuster/TXT Wheel Hub Adapters at CPE
http://crawfordperformanceengineering.c ... cts_id=638
Post by Sixtys Guy » Sun Aug 21, 2016 8:18 pm
GRAVETXT-1 wrote:My tiny brain is confused which Thunder Tech adapter do I need to get so I can install Clod wheels on Wheely King axles?
Alex, I will test fit up one tonight..... I suspect it is the 32mm.
Post by andymac0035 » Mon Aug 22, 2016 3:03 am
http://www.thundertechracing.com/adapters.htm
"Wheel Widener kit for Clod / Jug DEL-CB02b (1 1/4"32mm total width) works with Clod or TXT-1 wheels"
^^^^ those are the one's I used to use: DEL-TXT01
They have 12mm hex on the backside, and both clod and txt wheel patterns on the front.
Last I knew Brad still had these in stock. They are made of delrin too, very tough, I never broke or stripped one.
Thunder VP
Post by Thunder VP » Sat Aug 27, 2016 2:19 pm
DEL-AX02b is a better fit. These are customized for the Axial and HPI 12mm wheel hexes.
Brad, Thunder Tech Racing V.P.
Post by GRAVETXT-1 » Sat Aug 27, 2016 6:39 pm
Thunder VP wrote:DEL-AX02b is a better fit. These are customized for the Axial and HPI 12mm wheel hexes.
Brilliant thank you. And thank you to everyone for the reply's.
