Ball diff help
Ball diff help
Post by vwjuice » Sun Dec 23, 2012 3:38 am
I don't have the directions for the ball diff. Which way does the diff mount in the gear box?
Thunder VP
Re: Ball diff help
Post by Thunder VP » Sun Dec 23, 2012 3:53 am
The wide side without the gear goes into the wide side of the gearbox.
If you try to put it in wrong, the gears would keep it from going in far enough to close the gear case.
Re: Ball diff help
Post by vwjuice » Sun Dec 23, 2012 4:53 am
Thanks. I had found that out after I posted this. :oops: :lol:
highroller54
Re: Ball diff help
Post by highroller54 » Tue Dec 25, 2012 3:24 am
what should a guy use for grease on the balls?
Re: Ball diff help
Post by SFC K » Tue Dec 25, 2012 3:40 am
highroller54 wrote:what should a guy use for grease on the balls?
:lol: :lol: I'm not sure if I should take this seriously or not???? :lol: That is funny!
highroller54
Re: Ball diff help
Post by highroller54 » Tue Dec 25, 2012 4:21 am
:shock: I need to proof read things before I hit submit lol
Re: Ball diff help
Post by vwjuice » Tue Dec 25, 2012 11:01 pm
:shock: :shock: :shock: :shock: :shock:
Personally I like mine dry with maybe a little lube, but that's about it. :lol: :lol: :lol: :lol:
On a serious note, I use Team Associated diff lube. It works really well.
Re: Ball diff help
Post by SFC K » Wed Dec 26, 2012 2:28 am
vwjuice wrote::shock: :shock: :shock: :shock: :shock:
LOL, yeah on a serious note, I use Traxxas and Losi diff lube. Mostly on the heavy side for crawling...
highroller54
Re: Ball diff help
Post by highroller54 » Wed Dec 26, 2012 4:11 am
perfect, Thanks guys! If i had a lhs stuff like this would be allot easier.
Re: Ball diff help
Post by vwjuice » Wed Dec 26, 2012 4:26 am
As long as you use one of the big guys products you'll be good. I prefer Associated just because it seems to be the easiest to find.
