do you know
Moderators: Thunder Tech Pres., Thunder VP
Re: do you know
Post by andymac0035 » Thu Feb 09, 2012 3:49 am
bbytraction wrote:
andymac0035 wrote:They actually calibrated very easy. Sometimes the rear stalls, but not usually.
I run them off of one lipo, usually a 3S 50C, but have used a 2S 30C as well.
did you keep the two bec working together . dual steering or single , what servo are you using .
it was last winter last time I try i m taking the dust off and all go out soon
thank you
-No, I snipped a wire on the Y-harness (rear motor/esc)
-front steering only
-CPE 200 oz/tq servo
bbytraction
Re: do you know
Post by bbytraction » Fri Feb 10, 2012 10:31 pm
thank you
hallo
is it the black one that we remove
thank you for the input
that one push crush rock like snow before feading time ..thats plow #1 at 11.1/2in wide.
Re: do you know
Post by andymac0035 » Fri Feb 10, 2012 10:34 pm
Nope, it's the red one.
I cut it at the Y-harness right before it connects to the esc.
(instead of cutting the esc wire)
bbytraction
Re: do you know
Post by bbytraction » Fri Feb 10, 2012 11:59 pm
andymac0035 wrote:Nope, it's the red one.
ok red thank you i will reconnect the 2 black ..i use a needle and pull the pin out.
im going to use CC BEC or HENGE UBEC for the receiver and the 2 1/4 scale steering servo.thank you so mutch for reply :biggrin:
