TXT-1 parts?
Moderators: Thunder Tech Pres., Thunder VP
FlashGordon1
TXT-1 parts?
Post by FlashGordon1 » Fri Feb 03, 2012 1:28 am
Hay Brad I was wondering,could someone like my self still order this TXT-1 CVD axle kit
MIP-TXT01 $60.00
TXT-1 Straight axle kit
MIP-TXT02 $50.00
Txt-1 Aggressor Steering System.
Thunder VP
Re: TXT-1 parts?
Post by Thunder VP » Fri Feb 03, 2012 2:37 pm
The CVD kit for the TXT-1 is the same as the Clod Cvds, it just had slightly longer wheel bolts. We should be able to put those together.
Staight axles -same as Clod straights -out of stock, no plans to make more.
Aggressor steering, may not be in stock, but can be made to order at any time.
FlashGordon1
Re: TXT-1 parts?
Post by FlashGordon1 » Fri Feb 03, 2012 5:38 pm
Thunder VP wrote:The CVD kit for the TXT-1 is the same as the Clod Cvds, it just had slightly longer wheel bolts. We should be able to put those together.
Ok I will let you know when I am ready!
FlashGordon1
Re: TXT-1 parts?
Post by FlashGordon1 » Fri Feb 03, 2012 5:54 pm
Now let me ask you this while it is still in my mind. Now do you and Darren sill have the screws for the TXT-1? And what about the long pins? At the gear cases?
Thunder VP
Re: TXT-1 parts?
Post by Thunder VP » Fri Feb 03, 2012 8:21 pm
I'm sure we would have the propper bolts. If not, easy enough to get them.
What pins are you asking about? If its the center pin that goes between the axles, its no differant than the Clod
FlashGordon1
Re: TXT-1 parts?
Post by FlashGordon1 » Fri Feb 03, 2012 8:38 pm
Thunder VP wrote:I'm sure we would have the propper bolts. If not, easy enough to get them.
I thought that they are longer!
