need sway bar!
Moderators: Thunder Tech Pres., Thunder VP
tiktok
need sway bar!
Post by tiktok » Wed Apr 21, 2010 12:40 am
what is the swaybar that is included with the ripper pro chassis and is it available by itself?
Thanks!
-Matt
Thunder VP
Re: need sway bar!
Post by Thunder VP » Wed Apr 21, 2010 2:43 am
The sway bars included in the Ripper kits are formed music wire (.068" I believe) with links down to the lower 4-link bars. Same as is in the Rage kits.
I don't think we ever added the stock sway bars to the online store but you can shoot us an email request at: Thunderrc@aol.com
Also available are the CNC heavy duty sway bars. These have 1/8" thick sway links.
tiktok
Re: need sway bar!
Post by tiktok » Wed Apr 21, 2010 12:09 pm
is it possible to just buy your CNC ends on the heavy duty swaybar, and if so how much?
-Matt
Thunder VP
Re: need sway bar!
Post by Thunder VP » Thu Apr 22, 2010 3:56 am
We have a few of the CNC sway kits in stock info and can order here:
http://www.thundertechracing.com/online ... php?cat=39
TeamCHR
Re: need sway bar!
Post by TeamCHR » Wed Mar 07, 2012 4:31 am
Is the CNC Sway Bar Kit still avaible for the non Pro Ripper? I just picked up a used one and would like to go that route.
Signed: Cap Henry
Thunder VP
Re: need sway bar!
Post by Thunder VP » Thu Mar 08, 2012 12:48 pm
I believe we still have some of the adapter plates, but are out of the CNC arms.
I saw that mhesse (on RCMT) was making a version of the arms.
TeamCHR
Re: need sway bar!
Post by TeamCHR » Thu May 31, 2012 6:36 pm
Finally got the truck and I'm working on redoing it, I contacted Mike Hesse about the bars and arms already, does anyone have a set of the adapter plates they'd sell, or even let me borrow to have another set made from? Thank you
Signed: Cap Henry
Thunder VP
Re: need sway bar!
Post by Thunder VP » Fri Jun 01, 2012 1:42 am
As stated, we should have some of the adaper plates. If not, I could always make up a set in aluminum or CF.
TeamCHR
Re: need sway bar!
Post by TeamCHR » Fri Jun 01, 2012 1:11 pm
Brad, I emailed Darren and he said none were available.
A set in CF would be great! PM or email me please, cap@henrymotorsports.com
Thank You Sir!
Signed: Cap Henry
