Locked rear with steering
nascarcoffin9
Post by nascarcoffin9 » Thu Sep 24, 2009 2:18 am
I have a clodbuster monster truck that I built from scratch and I am using the Clodbuster/TXT-1 straight axle in the rear. I would like to have rear steering again because the course we are running has tighter turns than it used to. I have the aluminum locked diff spool gear. Would I be able to use the regular cv shafts? The truck runs great I get a great whole shot with the locked rear and the truck made the old turns just fine but now everyone is wooping my butt in the turns. Need info.
THANKS
Why spend money to have an r/c truck when you could have a real one? HA yea right, r/c trucks are a blast and my r/c truck can outrun your "REAL" truck anyway.
Thunder VP
Re: Locked rear with steering
Post by Thunder VP » Fri Sep 25, 2009 3:39 am
The locked dif will hurt your turning radius as much as adding rear steer will help.
Choices: return to full open dif
Add CVD's and steering servo to the rear. (CVD's will be back in stock soon)
nascarcoffin9
Post by nascarcoffin9 » Sat Sep 26, 2009 2:51 am
OK so go back to stock set up. I didn't think haveing the locked rear would help except in the straight line races. I have the CVDs that were originally in the truck when I built it. I just need to buy a new open diff gear. What would you recomend? The stock plastic or the nylon diff gear set? Thanks for the help.
Thunder VP
Post by Thunder VP » Sat Sep 26, 2009 2:10 pm
All the racers I talk to use the stock plastic gears.
nascarcoffin9
Post by nascarcoffin9 » Sat Oct 10, 2009 12:38 pm
Did you guys get any cvd kits in yet for the clod?
Thunder VP
Post by Thunder VP » Thu Oct 15, 2009 10:01 pm
MIP had a big order from another company that pushed our order back a little longer than planned. We hope to have them 1st week of Nov.
Post by charliechristmas58 » Mon Dec 07, 2009 4:53 am
any word
NOUSEFORANAME
Post by NOUSEFORANAME » Tue Dec 08, 2009 12:51 am
charliechristmas58 wrote:any word
viewtopic.php?f=13&t=17883&p=198905#p198905
:wink:
Post by charliechristmas58 » Tue Dec 08, 2009 1:45 am
ok thanks
