Alumn Hex's
run2jeepn
Alumn Hex's
Post by run2jeepn » Fri Apr 20, 2007 12:11 pm
Is there anyway to get some replacements or better yet. Alumn hex's for CVD's and Straight alxes? Also the Pin that goes through the joint needs to be a little bigger. The plastic hex and the pins are the weak links. I'm in dyer need of Alumn Hex's....Maybe offer them as extra. in 12mm and 14mm sizes.
Bolt_Crank
Re: Alumn Hex's
Post by Bolt_Crank » Mon Jan 28, 2008 12:03 am
A bit late... But yes, they have aluminum hexes now, in 12, and 14mm.
And I haven't had any problems with the pins yet... Though, I've only stripped 2 hexes...
Jiggy jiggy wham wham YEAH!
Heathen
Re: Alumn Hex's
Post by Heathen » Mon Mar 17, 2014 9:40 pm
anyone know when more might be coming?
Hooked since 95
stangnomore
Re: Alumn Hex's
Post by stangnomore » Tue Mar 25, 2014 1:02 am
Contact Mike Hesse @ www.hessemachine.com
I am ZRP Racing!
Heathen
Re: Alumn Hex's
Post by Heathen » Sun Mar 30, 2014 3:17 am
done thanks for the tip
Hooked since 95
