Differential Suggestion!
Support forum for Thunder Tech Racing.
http://www.thundertechracing.com/
Moderators: Thunder Tech Pres., Thunder VP
Bolt_Crank
Post by Bolt_Crank » Thu Feb 15, 2007 12:30 pm
I think y'all should try and make a diff that's sealed, so us gear loving diff guys can have some sort of fluid tuning vs. ball diffs...
Jiggy jiggy wham wham YEAH!
bbytraction
Re: Differential Suggestion!
Post by bbytraction » Fri Jan 30, 2009 9:28 pm
heavy grease on seams & bearing keep oil in not to bad
that one push crush rock like snow before feading time ..thats plow #1 at 11.1/2in wide.
Renegade
Post by Renegade » Fri Jan 30, 2009 9:41 pm
No oil stays in a clod diff because they are wide open...
TEAMCHAD: Newbie/ Wheelman
Bolt_Crank
Post by Bolt_Crank » Sat Jan 31, 2009 1:19 am
Not even 120,000 weight oil will stay in the Clod diff :lol:
The only thing I can think of, which could be incredibly messy, is to fill the entire bottom half of the gear case... And hope it doesn't leak :lol:
bbytraction
Post by bbytraction » Sat Jan 31, 2009 1:21 am
I've been putting grease at the seams, bearing and axel. It's not an o-ring, you get a drip here and there other than that it's been holding five to eight grams of oil. It keeps the gear slippery and from wearing and it works for me. It makes me happy!!!! :lol:
:p
Bolt_Crank
Post by Bolt_Crank » Sat Jan 31, 2009 1:35 am
Just gotta find a way to fill it up enough to affect the diff, and not touch any of the other gears...
It would be much easier if someone just made a sealed diff for it :lol:
bbytraction
Post by bbytraction » Sat Jan 31, 2009 1:53 am
ya I agree.the ball diff would get tighter more positraction whit thick oil insted of opening gearcase to adjust it, :?:
bbytraction
Post by bbytraction » Sat Jan 31, 2009 1:58 am
I run dual lock to work, have been thinking to get ball diff im scare of agjustment a other reason to open de gear box. :?:
Bolt_Crank
Post by Bolt_Crank » Sat Jan 31, 2009 2:05 am
The ball diff won't really be affected by oil in the gear case...
What I want is a bevel gear diff (just like what's in there stock) that's completely sealed so I can change the fluid in it...
My Clod has uber power, and I want uber reliability of set it and forget it... Ball diffs are nice, but TTR doesn't make them anymore, so getting a rebuild kit might be difficult...
bbytraction
Post by bbytraction » Sat Jan 31, 2009 2:29 am
is that what tunder tec coming out whit seal gear case. :?: thunder s got a ball diff
Bolt_Crank
Post by Bolt_Crank » Sat Jan 31, 2009 11:21 am
Nope... Thunder Tech isn't coming out with a sealed anything... I think they might have or are working on delrin axle tubes or cases... But they've discontinued the ball diff.
