Aggressor Steering Shipping Nov 21st.
Thunder VP
Post by Thunder VP » Wed Nov 16, 2005 12:09 am
After a little rework we came up with a version that we could get out on the street faster. The kit will sell for $45 and start shipping on Nov. 21st.
Here's a couple preview pics of the new layout.
RcK cRwLr
Post by RcK cRwLr » Wed Nov 16, 2005 12:48 am
A+ job :wink:
MIke
http://www.GSRCRC.com
r(k (rw1r
clodfuji
Solid Works Users
Post by clodfuji » Tue Nov 22, 2005 7:34 pm
Nice looking model
"You can't lose if you don't play"
Shelby VNT
Post by Shelby VNT » Wed Dec 14, 2005 6:41 pm
That's very nice! That is a true ackermann steering set-up, correct?
Do you guys have a spacer or washer of some kind that drops into the stock molded in, countersunk hex shape on the knuckles? (where the stock ball ends, which are hexes, slip in and are captured from turning) I think it would be helpful so when you tighten up the steering links to the knuckles you aren't actually compressing the link to the knuckle and causing drag from contact.
How do you guys do it? It looks like you have a spacer of some kind on the top of the knuckles, but what about the bottom?
-Nathan-
Sufferin' Succotash
Thunder VP
Post by Thunder VP » Sun Dec 18, 2005 5:53 am
The Aggressor system corrects the negative ackerman of stock or other forward facing steering setups. The crosslink mounting nuts are captured by molded drop in hex caps. The bottom of the crosslink is countersunk to give a flush screw head and less twisting force on the screw.
FlashGordon1
Re: Aggressor Steering Shipping Nov 21st.
Post by FlashGordon1 » Fri Mar 26, 2010 2:45 am
Thunder VP wrote:After a little rework we came up with a version that we could get out on the street faster. The kit will sell for $45 and start shipping on Nov. 21st.
Hay I was thinking very hard when I was working today! I am using my setup like the clodzilla chassis. I am using cvd's in the front and straight axles in the rear. Could I use that aggerossor steering on this project of mine?
Thunder VP
Post by Thunder VP » Sat Mar 27, 2010 5:02 am
Upper 4-link bars need to be relocated to the top of the gearbox, but otherwise should work just fine for you.
FlashGordon1
Post by FlashGordon1 » Sat Mar 27, 2010 11:26 pm
Ok but how can it be done? Because I made my own chassis remember?
Thunder VP
Post by Thunder VP » Sun Mar 28, 2010 2:46 am
For starters you will need an upper link mounting kit. Depending on your current link layout, you may need to move where they mount on the chassis.
Any pics of current set up?
FlashGordon1
Post by FlashGordon1 » Sun Apr 11, 2010 4:05 pm
Thunder VP wrote:For starters you will need an upper link mounting kit. Depending on your current link layout, you may need to move where they mount on the chassis.
I will send you a pm of them! and hear is some for everone else
Jeep-Power
Post by Jeep-Power » Thu May 31, 2012 3:12 am
these still available?
Thunder VP
Post by Thunder VP » Thu May 31, 2012 3:32 am
Yes, and in stock
