CVD's, Straight axles, Ball Difs.....(new pics added 8/20/05
FlashGordon1
Re:
Post by FlashGordon1 » Fri Sep 24, 2010 4:46 pm
Thunder VP wrote:Here are a few new pics with our first sample parts. These have not been hardend or plated yet but we thought all of you would like to see some accual parts installed.
Brad,do you have any pic's of the CVD's on a TXT-1? Thanks
Thunder VP
Re: CVD's, Straight axles, Ball Difs.....(new pics added 8/2
Post by Thunder VP » Fri Sep 24, 2010 10:39 pm
I do not.
Fit is the same as the Clod though just uses longer mount screw if using stock TXT wheel hubs.
FlashGordon1
Post by FlashGordon1 » Sat Sep 25, 2010 12:50 am
Thunder VP wrote:I do not.
Ok and thanks Brad. But I was wondering if the center gear pin is a different size? Cause I was looking at a few pic's over at rc4wd.
Thunder VP
Post by Thunder VP » Sat Sep 25, 2010 5:19 am
same pin in both
FlashGordon1
Post by FlashGordon1 » Sat Sep 25, 2010 5:25 am
Ok,thanks :D
FlashGordon1
Re:
Post by FlashGordon1 » Fri Mar 18, 2011 1:54 am
Hay Brad. I was wondering what is the size of the hubs that came with the cvd's and the straight axles?
Thunder VP
Post by Thunder VP » Sun Mar 20, 2011 3:55 am
The hexes have an 8mm bore.
Post by Budhatrain » Sun Mar 20, 2011 4:11 am
so any update on when these will be re-released- CVD's
Thunder VP
Post by Thunder VP » Mon Mar 21, 2011 1:01 am
Order for 200 sets (70 presold to venders) is going into MIP this week. MIP said about 6 weeks to complete the order.
todd ritchings
Post by todd ritchings » Mon Mar 21, 2011 1:30 am
I'am up two sets!
Post by Budhatrain » Mon Mar 21, 2011 1:57 am
are you going to presale these on your website?
Post by SFC K » Mon Mar 21, 2011 1:59 am
Budhatrain wrote:are you going to presale these on your website?
That is a good question. :D How much will they cost for a set?
todd ritchings
Post by todd ritchings » Mon Mar 21, 2011 2:20 am
45.00 a set
lude98r
Post by lude98r » Mon Mar 21, 2011 2:35 am
hopefully 45 but ill guess they will be 60 per set.
Are the straight sets being done again also?
Post by Budhatrain » Mon Mar 21, 2011 3:48 am
I bet more than $60... 65-70
