CVD's, Straight axles, Ball Difs.....(new pics added 8/20/05
Moderators: Thunder Tech Pres., Thunder VP
RcK cRwLr
Post by RcK cRwLr » Sun Aug 21, 2005 9:40 pm
Ok OK im an idiot sorry :oops: :oops: :oops:
MIke
http://www.GSRCRC.com
r(k (rw1r
shagrat69
Post by shagrat69 » Thu Aug 25, 2005 8:02 pm
i pre-ordered my full F/R CVD setup!!!.........have you?? :D
Thunder VP
Post by Thunder VP » Sun Aug 28, 2005 1:13 pm
Here's a few pics of first item straight axles. Final product will have a couple minor changes. Enjoy!
The CVDs should be shipping in about 1 more week followed shortly by the straight axles.
bigmoose
Post by bigmoose » Sun Aug 28, 2005 10:46 pm
Those pieces are beautiful. It is great to see you guys once again leading the pack in innovative products.
Great job guys!!! 8) =D> :yoda:
Moose
Beer has food value, but food certianly has no beer value. :shamrock: :drinkers: :shamrock:
Thunder VP
Post by Thunder VP » Fri Sep 02, 2005 3:22 am
Latest update:
CVDs will start shipping on Sept. 15th with straight axles a couple days later. The ball difs will be a couple extra weeks to add a few last minute changes. These will help in setup and adjustment. Shipping date TBA soon.
Optional wheel bolts for use with wheel wideners:
SP-MF-25 (5x25mm bolt kit set of 4) $4.00
SP-MF-30 (5x30mm bolt kit set of 4) $4.00
These are serated flanged head hex bolts.
shagrat69
Post by shagrat69 » Thu Sep 08, 2005 7:50 pm
what are you just makein sure i wont get mine till i get back in town from work :wink: i was hopeing to get then this weekend :( LOL
guess i'll have to wait till i get home :roll: :wink: :lol: :lol:
shagrat69
Post by shagrat69 » Mon Oct 03, 2005 3:17 pm
just got back from work and finally got to see the CVD's and man the final product you sent me is awsome!!!!! thanks man!!! i can't wait to put them in!!!! :D :D :D :D :D
Shelby VNT
Post by Shelby VNT » Mon Oct 24, 2005 4:05 pm
These are some of the coolest Clod parts I've ever seen come along from anyone in a while. Very nice. I have a set of the adjustable ball diffs on order from RC4WD.com. I would have ordered direct, but one of the other items I wanted from RC4WD was not available, so I asked to substitute some differientials.
-Nathan-
Sufferin' Succotash
ClodDude
Post by ClodDude » Mon Mar 06, 2006 6:06 pm
Hey Brad,
I just got the Stright axles and CVDs and they are AWESOME!!! :D
I'm using them in a puller project of mine and I was wondering if you could tell me your best guess of how much weight these axles can take. I have JPS cases and axle tubes and steel gears.
I'd rather get a ballpark guess than hear the crack of the axles telling me what it really is. :wink:
Thanks!
Your journey of over a thousand dollars begins with just one Clod.
Clod...why can't I quit you?!?
Thunder VP
Post by Thunder VP » Wed Mar 08, 2006 5:20 am
Can't say for sure yet. I haven't had time to convert one of my pullers over to them yet to truely test the limits. Although we have used a set of front CVD axles in a 4wd stratch built truck and they work great.
I would say on dirt they will hold up to anything you can dish out. On carpet the CVD's in the front should hold up to any weight, the rear straight axles, I would say they should hold up over 300+ lbs. (dragging sled weight) This is only going by past experiance in building Clod pullers.
Ragin' Steel
Post by Ragin' Steel » Sat Apr 01, 2006 2:06 pm
When do you think you'll have more CVD's in stock again? :D
Thunder VP
Post by Thunder VP » Tue Apr 04, 2006 3:26 am
They are in production as we speak. If all goes well we should get them from MIP in the next few days. (we should be alble to ship backorders by 4/10/06) A few minor changes are being implimented as well. A couple extra degrees of movement have been added, and a change to the mounting bolt threads from 5mm to 10-32. The thread change was so we could use a better selection of serated flanged head bolts. This will aid in keeping the bolts tight durring use. The splines have now been added as well, so they can be used on the TXT-1 and Jug trucks also.
NOUSEFORANAME
Post by NOUSEFORANAME » Sat Sep 23, 2006 3:01 am
Will these work with Inet Alloy Knuckle Arms, does the straight axle require a lockout for support, and are there rebuild kits for the cvd joints?
Thunder VP
Post by Thunder VP » Sat Sep 23, 2006 5:20 am
They should work fine with the Inet parts.
Straight axles do not require a rear lockout to be installed, but one can be used if you like.
Rebuild kits are available.
NOUSEFORANAME
Post by NOUSEFORANAME » Sat Sep 23, 2006 3:53 pm
Thanks for the info,
Do you stock the rebuild kit, what part # do I use, couldn't find it on your website.
