Just picked up a Twin Force and wouldn't mind a better chassis than the stock one.
James
Moderators: Thunder Tech Pres., Thunder VP
http://www.GSRCRC.comihaveabruiser wrote: As far as all non crawler builds go, they go in chit chat, this is RCCrawler not clod talk :flipoff: :flipoff:![]()
MIke
The long swingshaft will be used in place of the center driveshafts on the long wheelbase configuration? You don't think the swingshafts are too weak for this? It seems that the center drive shafts are a bit thicker than the swingshafts used in the axles...Thunder VP wrote: Extended wheelbase usage will require the Kyosho long axle swing shaft # MA024 or equivalent.
(Not sold or provided by Thunder Tech)
Sounds good. Now I only have to wait about 3-4 more weeks.Thunder VP wrote:The stock center axles are 5mm thick at the ends but have a section in the center thats 4.8mm thick. The long axle shafts are 4.8mm the whole length.
I've used the long swings on my Mad Force in a long wheelbase settup and the axles hold up fine as long as you are using braces on the link bars to keep them from over torqueing and bending the axles.
I've seen some guys run Revo axles in the center as well.
We just provided the option for the long wheelbase in the chassis but are not planning to offer a drive shaft replacement.
