Register •
FAQ
• Search • Login
| Please help support ClodTalk.com! Any contribution helps!! |
Page 1 of 1
[ 6 posts ] |
| Author |
Message |
Gregg
I am trying to build an 8x8 Military truck called the HEMMT. what I want to do is have 2 front steerable axles and 2 rear non sterable axles. I want to use 1.9 size tires and wheels. Can anyone suggest a good combination of axles to use? As I said I need both front axles to steer but straight rear axles so I need 1 front, 1 front with straight through drive and 1 rear with straight through drive and 1 reat standard axle. I was originally going with Clod buster axles but these will not let me get the axles close enough for the scale apparance I am looking for. Any sugestions would help. I am also looking to keep the price of each axle below 100.00 dollars US. Thanks.
| Wed Sep 21, 2011 9:15 pm |
Life Saver
Joined: Sun Sep 17, 2006 11:12 pm Posts: 6644 Location: Angleton Texas
There is a guy who is on e bay joes truck stop you might ask him he builds all kinds of trucks
_________________ Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming to the Lord, "Wow, What a ride!"
| Wed Sep 21, 2011 9:27 pm |
Gregg
Thanks charlie
| Wed Sep 21, 2011 10:05 pm |
Life Saver
| Wed Sep 21, 2011 11:16 pm |
Gregg
Well I'm really at an impass at the moment. i can either find front axles that mate by a shaft but cant seem to find a set of four axels that can all work to gether from a transfer case. The front 2 need to be able to steer and the back 2 need to be locked. Now I know plenty of guys have made 8x8 trucks but I am a complete noob as far as the truck hobby goes. I can tell you anything you ant to know about rc tanks but trucks for get it. I really ant to keep this truck in the 1.9 tire scale so I could really use some help. i looked on the site that was recommended but he only had a set of front axles and they did not seem to be fun in series. So Help Please. LOL
| Fri Sep 23, 2011 1:50 am |
Thunder VP
Company Owner
Depending on the width you require, there are options out there but you will need to buy the axel parts separately. Many guys use Axial brand crawler axels. You would need extra back halves and pinion gears to make the center pass through axel setups. Straight shaft adapter parts are also available. Tamiya TLT axels are also common for this.
_________________Brad, Thunder Tech Racing V.P. http://www.thundertechracing.com
| Sat Oct 01, 2011 6:36 am |
Page 1 of 1
[ 6 posts ] |
Who is online |
Users browsing this forum: Google Adsense [Bot], SLUFOOT1 and 0 guests |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
| Help support ClodTalk.com |
This
forum is supported by:
