View unanswered posts | View active topics It is currently Fri Sep 10, 2010 11:43 am
Reply to topic  [ 7 posts ]
 NEED A BEC
Author Message
Post NEED A BEC
I need a good BEC for my crawler and im new to this and i dont know what i need. i was told to get the castle. I have the crawler Rooster ESC and the Novak 55's motors. the red wire is cut to the ESC so i have to use a BEC. any help well be appreciated. :D
_________________
Sun Feb 28, 2010 2:44 am
Profile YIM WWW
Post Re: NEED A BEC
yep the castle is the one to use..it will give you as much volts as your servo can take and it puts out 5amp constant 10 amp peak..it will have a default setting of 5 or 5.5v, if you have a castlelink you can go to 6v or more depending on your servo..you could also use a rx pack from a nitro if you have one to get you going in the meantime..it,ll probable run you 20-25 bux and they are redilly available at the lhs :)..if your not running a hot servo you might be able just solder on a new red wire with the little metal plug on the end..usually i dont cut the red wire i just pull it out of the plug and tape it up..the novak has a not too bad built in bec..about twice the power of a mamba so if you just running i servo it might be just enough..what servo/s
Sun Feb 28, 2010 2:54 am
Profile
Post Re: NEED A BEC
Its 1/8 has high tork servos its 4x4x4. they cut it on the ESC. so its to short to do any thing with it now. why i dont know. what batterys should i use? for the servos and the crawler? and thanks for the info. :D
_________________
Sun Feb 28, 2010 3:21 am
Profile YIM WWW
Post Re: NEED A BEC
ok i think you posted pics awhile back..some really kick Halgars trucks are cooler than mine servo,s there..definatly need a bec :shock: are you gonna go lipo..if so you could definatly try some of the cheaper lipo,s out there like turnigy or zippy,s..i,ll give you a link to hobby city..massive seection of lipos in pretty much every size and config..in your case 2s with the rooster crawler..its a matter of the space you have to work with..i think the cheaper lipo,s are fine as long as your not putting huge loads on them and a crawler setup will be ok with these..go for 20+c rating i use 2200 up to 4000mah to keep the weight down..i like to mount them usually on top of the skidplate..heres a link to the batts http://www.hobbycity.com/hobbycity/stor ... All+brands)&idCategory=86&ParentCat=85
i usually use flightpower pack as they were the shiz when i bought them and the sizes worked for me, also have some hyperion pack that i,m not too sure about..charge real quick but seem not to be very well matched..cells which is pretty important with lipo,s, also have a few turnigys and are fine..if your running nmh i dont really know anymore as i dont run them anymore
Sun Feb 28, 2010 4:02 am
Profile
Post Re: NEED A BEC
im thinking of going lipo. the space is limited. also look at the ESC and the wire they cut is a jumper. so i can get a new one at the lhs. it also says if im going to use lipos to use 2 lips cells. is that two of them? :?
_________________
Sun Feb 28, 2010 6:23 am
Profile YIM WWW
Post Re: NEED A BEC
a 2s pack means 2 cells or 7.4v,,each cell is 3.7v instead of 1.2 like a nmh
Sun Feb 28, 2010 6:49 am
Profile
Post Re: NEED A BEC
ok. thanks for the info. :D
_________________
Sun Feb 28, 2010 6:03 pm
Profile YIM WWW
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Help support ClodTalk.com
Donate towards my web hosting bill! Help support this forum!  Any contribution
is greatly appreciated!
Click here for more information!
Green Web Hosting! This site hosted by DreamHost.
This forum is supported by:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
Designed by STSoftware for PTF.
